Hi there, I have been leafing through the excellent transistor circuit samples over at talkingelectronics.com, however they provide quite a minimal degree of commentary on each circuit, and while I feel I am gaining an understanding I wish to make sure I have understood it right.
In particular I am looking at the 5 transistor radio as shown in the attached picture. I will state how I understand the circuit below, if anyone could point out errors in my understanding I would be very grateful.
Stage A: 10n between (+) and (-) stabilizes voltage
R1 100k resistor provides V splitter with R3 100k/110k * 3V = 2.7V, applied to antenna coil
Output of antenna is fed to a darlington pair of BC547s,which amplify the antenna signal twice. Output is sent across 100n staging capacitor to stage B in the form of varying voltage.
Stage B: signal from Stage A is sent into another transistor to be amplified.
Voltage splitter of 10k+220k ensure that the 100n staging cap going into stage C receives 220k/230k * 3V = 2.86V at peak. Stage A signal turns base of stage B trans on/off, which turns current through transistor on/off, which turns voltage at the 100n staging cap going into stage C on/off. (Why is this stage necessary? more amplification of signal?)
Stage C: Output from stage B is sent into base of PNP transistor, which is connected to another NPN below (darlington pair). R6 and R8 divide voltage giving 47k/57k *3V = 2.47V at base of PNP trans (if there is so much voltage here already how does the stage C staging cap influence the base? also why is so much voltage required for just the base of a transistor?)
Varying current through the NPN below the PNP flows through a transformer and speaker (the transformer brings the voltage down to half? why?) - which outputs the sound.
As you can see from my questions in parentheses, I am not quite sure of the purpose of some of these components. Any advice would be appreciated!
