Help please with transistors
GSimon850
Jul 11, 2014
9
image.jpg Hi all
First of all I have basic knowledge of electronics.
I am trying to fix a battery charger and need to change out the following transistor but cannot find them anywhere, is there an equivalent I could use.
The transistors are
A1015 GR 9E
And
C945 P 98C
Many thanks up front.
Simon
GSimon850
Jul 11, 2014
9
Additional information
The charger works but the LED does not light up to say its charged and switch off so constantly charging.
There is no voltage to the LED so I think it's the A1015 transistor at fault.
Cheers
Gryd3
Jun 25, 2014
4,098
View attachment 14012 Hi all
The transistors are
A1015 GR 9E
And
C945 P 98C
Simon
Here are a couple links to get you started.
Just do a google search and you get all sorts of results ;)
http://www.digikey.ca/product-searc...roducts/transistors-bjt-single/1376376?k=1015
http://www.digikey.ca/product-searc...roducts/transistors-bjt-single/1376376?k=c945
If you could please help us and label each one of the inputs to the board, it will make things easier.
https://www.electronicspoint.com/resources/photos-with-phones.27/
Arouse1973
Adam
Dec 18, 2013
5,178
Ebay seem to have both. The A1015 is a epitaxial transistor, dont quite know why its used in a battery charger. Maybe some of the other guys might know.
I'll see if I can draw a circuit for you over the weekend. But Kris will probally be on soon and beat me to it, he loves this sort of thing.
Adam
OLIVE2222
Oct 2, 2011
690
The transitor(s) can be board removed for check purpose (as the led) before replacement.
However both transistors are popular Japanese models.
2SA2015, European equivalent is BC557, same package different pinout
2SC945,European equivalent is BC547, same package different pinout
GSimon850
Jul 11, 2014
9
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
When you've replaced the transistors you should add a diode across the relay coil to protect Q2 against back EMF. This should have been included in the original design. The relay doesn't have a diode built-in. Here's how to connect it. Just tack it on the underside.
Arouse1973
Adam
Dec 18, 2013
5,178
I knew you'd have a go Kris, well spotted. Just wish that I had time last weekend to have a go
Adam
GSimon850
Jul 11, 2014
9
Thanks dude
Really appreciate your help with this. I have got these ones on order from Ebay.
50Pcs 2SA1015 PNP PCB Surface Mount General Purpose Transistor 50V 0.15A
Hope these are the right ones to replace the A1015 GR 9E transistor.
Like I said a bit out of my depth here.
Arouse1973
Adam
Dec 18, 2013
5,178
Thanks dude
Surface mount, are you sure?
Adam
GSimon850
Jul 11, 2014
9
Adam
Sorry but these are the ones I ordered cannot take pic off iPad but this is the item number off Ebay
291182500729
From the picture they don't look like surface mount transistors. I have trouble seeing normal components without the aid of a magnifying glass. Lol
davenn
14,479
no they are NOT surface mount transistors
scarey that the seller doesn't even know his product !
Dave
Supercap2F
Mar 22, 2014
550
He most likely does know what he is selling. What sellers will do is add a bunch of somewhat random words to there title, so when you search one of
those words it will bring up there listing.
Regards
Dan
davenn
14,479
Regards
Dan
I guess that is a possibility
But then its just false advertising and confusing for someone who is relatively new in electronics
Dave
GSimon850
Jul 11, 2014
9
Dave
Yes it can get very confusing so thanks all for sticking with me on this really appreciate it. As soon as the transistors arrive I will replace the A1015 transistor and add the diode. Fingers crossed. These are coming from Hong Kong so expect them to land in a week or so.
Cheers again all
Simon
GSimon850
Jul 11, 2014
9
Cheers again all
Simon
Sorry chaps still not working any ideas?
