Do you think the leads are tall enough for me to bend the transistor and heat sink back over the other components? "If so, with careful layout, its possible to have the transistor bend over other parts after they are installed."
In other words, lay out some of the low lying items, smd caps, diodes, resistors where applicable and then bend the heatsink and transistor so it lays on top of these components, parallel to the board? Maybe use a nylon bushing to keep a specific distance off of the board and bolt it together through the board so that it cant short out on the other components.
I don't know if there is enough height on the leads to do it, but its a thought!
