- Joined
- Nov 28, 2011
- Messages
- 8,393
Yes that one looks good. You need to derate the thermal resistance because you don't have free airflow but I think that will be fine.
That is a great point, I was thinking about derating in general because the ambient temperature is typically around 85deg F in the environment where I will be using this device. I had read that you may have to derate because of higher ambient temps. Being only a few degrees higher, I wasn't sure if it was a factor.Yes that one looks good. You need to derate the thermal resistance because you don't have free airflow but I think that will be fine.
Yes there's a 0.6W "buffer". Yes, you should have copper on both sides with thermal vias, to improve heat dissipation. The tab is connected to the middle pin, i.e. the collector. In all TO-220 packages that I've ever seen, if the tab is metal and not specifically isolated from the component, it is connected to the middle lead.
Thanks Kris! You have been brilliantI think that, plus that heatsink, will be fine. No, you don't need a mounting kit because you don't need electrical isolation between the device and the heatsink.
No problem, just wanted to be sure I wasn't missing somethingSorry, that's a mistake on my schematic. It's a multi-layer ceramic capacitor (MLCC) and they are non-polarised.
With THT components, personally I just bend the leads slightly. With SMT you can use a dab of glue but I find it easier to tack one corner pin, adjust alignment if necessary, tack the opposite corner pin, adjust alignment if necessary, and solder all the other pins. I don't think tape would help.
Edit: For SMT capacitors, firm downwards pressure with tweezers etc should be enough to stop it sliding around during soldering. You can tin the first pad, place the component, and while pressing the component with tweezers in one hand, flow the solder using the iron in your other hand. Once the solder has cooled, solder the other end. Then tidy up the first end. Do everything quickly and allow it to cool completely between operations, so the heat doesn't flow through the component and melt the solder at the other end! Do several components in sequence so you aren't heating up the same component before it has had time to cool completely.
Not really. I recommend doing the corners first, whether you use reel solder or solder paste.I do have some solder paste that I intended to use for the smt components. I figured it would help to temporarily "glue" them in place while I soldered them.
Good to know, thanks again. Will you be able to give the BOM a look over when I am done? I am trying to be as meticulous as possible, but two sets of eyes are better than one.Not really. I recommend doing the corners first, whether you use reel solder or solder paste.
Thanks Kris, I will post in a few days. It is taking longer than I expected!Yes, of course. Post it here.
I thought we had chosen a high-efficiency LED (http://www.digikey.com/product-detail/en/LTL2R3KGD-EM/160-1852-ND/2675131) for the power indicator, to operate at 2 mA. That's the amount I allowed in the current budget. In that case, VF is typically 1.8V so R10 would be 1K6.
Looks good!
You might want to add chamferred corners instead of right-angles in tracks, but that's just cosmetic. You could add a pin 1 marking for the ICP connector, though you've used a polarised connector there so arguably that's not needed.
I did that as I constructed the BOM. As I entered each piece I checked the given size and pin out locations against my PCB.You could re-check the dimensions and pin positions and hole sizes for components like the relay, the 1 µF capacitor, electrolytics, connectors...
check and check, the only issue that came up was "drill distance", but when I submitted it to the board house, they didn't have an issue quoting it. Should I pursue the issue?Did it pass a netcheck? Did it pass a DRC including a clearance check? Have you inspected each layer individually?
