Yeah.. wasting power will do that.. This was the idea behind using a relayOkay..
Resistors came in... It's works great, but having the resistor on all the time, it gets HOT! I tried connecting 2 to see if I could share the load, but them they both just got HOT!
So then I thought I would check to see what voltage the center tap on the transformer was... It is 7.2v... But does the center tap still give 8A? Or only 1/2 (4A)?
-TheChad
My understanding of how transformers work would result in the center tap being able to provide twice the current capability at half the voltage of the outer-most leads.
If you were thinking of using that center-tap for a voltage source for your meter, you would require at least 1 diode and a capacitor to make a rough 'half-wave' rectifier to provide DC to the meter.
OK, now you have me really confused.
I thought you were using a switchmode regulator to set the output voltage? Why are you planning to change the taps on the transformer?
The resistors won't change the voltage, they'll just allow it to leak away after the power is switched off.
I think your original issue was that your front panel meter didn't turn off immediately after you removed the power. That's not a big deal, and it's not going to be fixed by changing the taps on the transformer.
You probably know exactly what you're trying to achieve, but I don't. Perhaps you can list all the problems you perceive the supply now having and we can discuss how to fix them (and indeed IF they need to be fixed).
It may be worth a try.. I'm thinking you may get closer to 10V though..
Edit: As Steve listed above, he pretty much nailed it.
Using the center tap instead to power the input of your switch mode voltage converter will result in a lower voltage, which could result in the meter powering off sooner, but I would call it a far from ideal solution.
Yes, that's right.So, connecting two 100Ω resistors end to end (series?) gives me ~200Ω.... Connecting two 100Ω resistors + to + and - to - (parallel?) gives me ~50Ω? Is that right? That's what I measured with the ohm meter...
In a sense... there is a formula for determining this.I am thinking in terms of batteries, If you connect batteries in Series they multiply, IE: 1.5v + 1.5v = 3.0v, however if you connect them in parallel, they maintain the same voltage 1.5v, but double capacity. So is that why a resistor measures 50Ω? because it doubled capacity of 100Ω = 50Ω? (Just trying to make sure I understand)..
The wasted power would be the same... but combined, two resistors are physically bigger and can dissipate the power into the air easier so two will feel cooler. A single resistor would concentrate the same wasted power in a smaller area and would be hotter. (Note that the temperature inside the case would be the same... it's just the individual resistors would vary)So if I were to order a 200Ω resistor, would it be as warm as the two 100Ω resistors in series? or will it be hotter because it's a single resistor instead of sharing the load over 2 resistors?
This would not quite be true... there is some more math required here that I don't know yet.For example would it be as hot as both resistors added together? if resistor A = 70-degrees and resistor B = 70-degrees, a single 200Ω resistor would = 140-degrees? or would the 200Ω resistor still only = 70-degrees?
You're welcome! (I think it's amusing how something so simple has exploded... you tend to get sidetracked like I do)Thanks again! It's almost done!!
-Gryd3-TheChad
-Gryd3
Before you do that.Yeah, I'm very analytical, I often over analyze things, I will do something, it will work, but I'll wonder if I could have or should have done it differently, even if the same result is achieved.
But I always try to do things the correct way, never 1/2-ass it or do something wrong just because it works...
Anyway, on that note, LOL...
I was browsing Mouser and found this: http://www.mouser.com/ProductDetail/Vishay-Dale/RE60G1000C02/?qs=sGAEpiMZZMtlubZbdhIBIDTODbDtFnrROxdF6lOjpss=
So I was thinking, maybe that is the ultimate solution, I can get 2 of them, wire them in series and glue them down to the power supply case, with the heatsink on the resistor and it being glued to the case, the heat will hopefully end up in the case instead of inside the power supply and keep the insides cooler.
-TheChad
http://datasheet.octopart.com/PCLH-206A1S-Tyco-Electronics-datasheet-15179.pdf
Before you do that.
What kind of spare parts do you have handy?
I'm interested in knowing the capacitor values, and if you have diodes kickin around...
The thought is powering your meter from the center-tap of the transformer, and building a very basic half-wave rectifier with a small capacitor and diode to 'regulate' the voltage to the meter.
Cheaper parts, and would waste less power.
This is what I was thinking for the meter.
Use the center tap. One diode, and a capacitor for the positive side to the meter. The negative goes to one of the other wires on the transformer.
All you need is a diode, you could try it with the 100uF capacitor. (Although, it may be too small depending on the draw of the meter.)
I'd go with the first one, but I don't like the priceThe operating current for the meter is <20mA according to the spec sheet.
The meter has an operating voltage range from 4.5v - 30v. Would it even need the capacitor?
http://www.radioshack.com/1n4004-mi...&sz=12&srule=Price-low-high&prefv1=RadioShack
OR
http://www.radioshack.com/3a-barrel...e-low-high&prefv1=RadioShack&start=6&tab=tab2
Would either of these be what I should get? Or something different?
Thanks!
-TheChad
