I have a treadmill that has a simple single pole fuse holder type 15 amp circuit breaker mounted next to the on-off switch on the bottom of unit. When removing the breaker I didn't take note of the wiring. Its a simple two prong female spade connector breaker with reset and there is no indication for proper wire connection, just technical spec writing on one side. Can this breaker have the two wires reconnected either way?
