looking for a "center-bore" motor
sidius
Aug 8, 2015
13
I see.
Well, this thread has become about mechanical engineering after we found no suitable shaftless motor and decided to separate the rotating part and motor. I should move this question to general/mechanical engineering forums.
One thing I should ask here instead though is, what motor should I get? Sync with the GPU refresh rate is essential to not get mess instead of a 3d volume.
CDRIVE
May 8, 2012
4,960
After looking at your latest drawing I'm a bit confused as to why you need such a large bore. The drawing seems to indicate that you're only passing a light beam through it. Am I misconstruing that?
Chris
sidius
Aug 8, 2015
13
That's not the light beam in the illustration, its the light beam path.
The light beam is a video projection that increases in size over distance.
CDRIVE
May 8, 2012
4,960
Can that be compensated for by using lenses?
Chris
sidius
Aug 8, 2015
13
No, lenses can't shrink a video beam to a tiny <1cm beam and than back so easy. If it was so simple I don't think previous works would waste so much time and money on expensive custom center bore motors or custom milled gears/parts. I mean if it was just a light beam maybe, but a projection has to remain the same in the end.
Someone into photonics explained the details to me once, but I don't remember it. I think it has to do with light scattering in a real world imperfect lens.
CDRIVE
May 8, 2012
4,960
It was just a thought, which is why I posted it as a question and not an option. Optics is not my forte.
FYI: The square frame pillow block bearings you posted employ a grease fitting located on the same real estate you're suggesting machining a V groove. You can't see it in the photos but take a look at the mechanical drawing.
Chris
sidius
Aug 8, 2015
13
Yeah, doesn't seem like a good idea because of play in the Y axis too.
It's a bummer that there arent any wide shaft motors either. We could always swap a shaft with a tube.
CDRIVE
May 8, 2012
4,960
There are large shaft motors. We had quite a few at the hospital I contracted at. Some as large as 3" but you'll need a crane to move them! :p
Chris
sidius
Aug 8, 2015
13
Yeah, so uh,
What motor would you suggest for a belt setup?
The rpm is going to be between 700 and 900, depending on what fps/volume ''resolution'' balance I end up with.
The rotation has to be in sync with the GPU fps (120 fps/s -> 15 or so rotations/s) .
It seems after I described what is gong to be rotating we agree not much torque is needed.
