I'm testing a NPN Darlington transistor to see if it is OK. Transistor is for an electronic ignition system on an ATV. Transistor marking ETD41-035. I'm using a Fluke 179 true RMS meter on the diode test setting. Here are the readings I'm getting.
B-C: .543 vdc
B-E: .639 vdc
C-B: infinite
E-B: 1.54 vdc
So going by the test procedure I should be seeing infinite E-B correct?
B-C: .543 vdc
B-E: .639 vdc
C-B: infinite
E-B: 1.54 vdc
