Mike Taylor
- Sep 11, 2015
- 21
- Joined
- Sep 11, 2015
- Messages
- 21
12v, 3A transformer, LM350T VR, 5A diode bridge, 22000 microfarad cap., 220 & 1K control resistors, 1mf cap. Large cap is on output side of bridge, small cap on out side of VR. Standard circuit diagram.
Volts on out side of bridge is 17. Volts on out side of VR is 7.1 under no load. Load is an 8' piece of nichrome wire, 1 ohm per foot, plus a large ohmite ceramic resistor. VR is on a large heat sink with fan.
Problem is the output voltage starts dropping once the current gets over 0.5 amps. At 0.65 amps the out volts is about 5.1 volts. The volts on the out side of the bridge only drops to about 16.5. If I decrease the load resistance more the out volts will go down to 2.5.
What am I doing wrong? I've run it for an hour at 7v and 0.5 amps. The heat sink stays cool. I need 7v and 2 amps. Same results with a 4700mf cap.
Mike
Mike
