Just want to say thanks in advance for any help I may receive! I am not an electronics guy although I did pass my electronics class with a B. Not great but not horrible either.
I have been beating my head over this problem for about a 2 months and have not yet arrived at a solution. So here I am. I have figured out a way to do it but its just ugly and I know there is an easy solution out there.
So here's the problem:
I need a switch that will automatically switch the current to another circuit every time the power is turned on. Here is a crude drawing that I hope helps you visualize the solution:
This is how the switch should run: power on/circuit A is on/power off/power on/circuit B is on/power off/power on/circuit A is on/.......
The power source is 24v and the load is 10amps.
I am using a motor to roll up some plastic and then unroll the plastic on a timer. The motor has a limit switch in it already so we don't need to worry about that.
Is there any product out there that fits the bill?
Thanks
James
Thanks
James
