Looking for some help in wiring up a 12v relay for my car.
Basically, I have a 12V relay that is activated with my windscreen washer circuit. So when the washer pump is active, the relay activates. Problem is that the relay only stays active for the period of time that I hold the washer stalk down. The moment the relay gets activated, I want it to provide power to my device for 3-4 seconds in one polarity and then for another 3-4 seconds I would like it to reverse the polarity before turning off completely. And also if for some reason the windscreen washer was to be activated again while the relay is still cycling through the first 3-4 seconds then it should not re-activate.
Would really appreciate some help on this.
Many thanks
Many thanks
