This piece was connected to the wiring for a small 12 volt heater inside a tractor cab. I'm guessing it's a fuse, but I'm not positive. I can't read the numbers on the back side because there is burnt plastic covering all of the numbers except the first 2, which is "22". The front side only says "3M".
If it is a fuse, is there any way I could go about replacing it, without knowing the exact specs for the fuse?
The 3rd picture is after I pried off the cover that says "3M".
Thanks!
Thanks!
