OrangeArav
- Jul 14, 2015
- 38
- Joined
- Jul 14, 2015
- Messages
- 38
Ok, but if you need to do a KVL to find the current ib can you just assume the voltage on R1 is Vin, or do you have to do the transformation first making a V source of value Iin*R1 in series with R1. Only then do the KVL and find the ib? What happens is you end up with Iin*R1 in the numerator instead of Vtest.Current source casceds,not much different than voltage source cascades:
when you drive an amp with a current source you need to use current dividers(parallel) instead of voltage dividers(series) and
multiply the chain like you did for voltage sources.
Rin,Rout are calculated the same the only difference:
an ideal current source has Rint=infinity.
an ideal voltage source has Rint=zero.
P.S. in the solutions Rin = 60.7k
