Hi All
Thanks for looking. I have what is probably a simple problem to solve but I don't want to try and solve it with trial and error as I usually would due to the costs of the micro pucks I use which are blown easily.
The circuit is very simple in that I use a PICAXE chip to switch on a N channel mosfet which in turn sinks a micro puck which then drives a high power LED. The problem is that the micro puck must be connected to the LED when powered otherwise they burn out. So if an LED blows or a wire is disconnected then the micropuck burns out at a significant cost.
I was hoping to overcome this by introducing some sort of feedback back to the picaxe from the LED. So if the circuit is broken in anyway then the pixace will immediately switch off the mosfet.
I have drawn a simplified version of the circuit and my question is what should I do to safely connect the feedback channel to the picaxe. Do I need a resistor in the feedback channel and or should I have a resistor and connect the leg of the chip to ground?
The circuit is powered by a 4.2V battery and the micro puck boast the voltage to 7V and holds the current to 500mah. The pic only works at 3V-5V.
I appreciate there is probably a very simple answer to this but any help would be appreciated as my electronics knowledge is very basic.
Thanks for your help.
JPU
JPU
