- Joined
- Jun 21, 2012
- Messages
- 4,985
You already have the "1.225 zener" in place on your original schematic post. Now you just have to provide a small negative voltage through a current-limiting resistor to its anode. I think the "-9V" circuit will provide that, but you don't need the voltage multiplication it provides. So, yes, substitute your device for the 9.1V zener and eliminate the extra parts. Probably you will need to increase the value of R1 and perhaps increase the value of C4 (to get an acceptably small ripple) but the extra diode D3 and capacitor C3 (used for voltage multiplication) are unnecessary IMO.
I know you already have the transformer and full-wave bridge, so wire those up along with a large filter capacitor but don't bother connecting the LM317 yet. From the circuit I posted above, add the capacitor C2, diode D3, current limiting resistor R1, output filter capacitor C4 and two series-connected 1N400x diodes to simulate your LT1004-1.2 (don't want to let the smoke out that by using too small a value of R1). Make sure the cathode of the diode string is connected to the junction of R1 and C4 and the anode of the string is connected to common.
Fire up the transformer and start measuring some voltages. Measure the voltage across the diode string: it should be about -1.4 V with respect to circuit common. Measure the voltage across current-limiting resistor R1: calculate the current through this resistor. Adjust the value of R1 for about 10 mA, which is about one third the maximum reverse bias current the LT1004-1.2 is rated to pass. If everything checks out, replace the two diodes with your LT1004-1.2. Remember to connect its "anode" to the negative output of current-limiting resistor R1 and its "cathode" to common. Go back and check the voltage drop across R1 to make sure the current is approximately 10 mA. Check the voltage drop across your LT1004-1.2 to make sure it is within ±4 mV of 1.235 V. If everything checks out you are ready to wire up the rest of your voltage-regulated power supply. Note that half of that 10 mA current budget flowing through R1 will be used by constant current flowing through your 240 ohm R3 resistor after the LM317 is connected.
The only reason I can think of for using op-amps is for current limiting circuitry. This is a nice feature for any bench supply, especially if it can be set for any current between zero and maximum. However, I think this is unnecessary for your first power supply project. The LM317 protects itself from overload, even extending to a short-circuit from output to common. Plus, you will have digital panel meters to monitor output voltage and load current, so variable current-limiting is just a whistle you don't need to tweet right now.
Please let us know the results of your breadboard experiment.
