lxlramlxl, I suspect that your requirements are far simpler than we tend to (sometimes) make things. If all you're desirous of doing is activating a current controlled relay then all you need is a power resistor like this. This 400Ω resistor will pull 300mA @ 120V and is rated at 50Watts.
Ebay lists quite a large selection of various resistance and wattage values.
Please tell us if your field tests require the return of any data. In other words since the dummy load will (as you say) tap into the existing circuit via Alligator Clips do you require an indicator that the relay contacts have closed?
It would help greatly if you could supply us with the resistance of the CCR. This way we can calculate the required value of the dummy load in series with it. An approximation of the input voltage isn't sufficient though. Is it in fact 120VAC?
Chris
Chris
