Because it need to be replaced
i test it with analog multi meter and it didn't measure for one coilhow do you know it's faulty ? how did you test it ?
here's the photo that show allCan you give us a photo of the flip flop / foil side of the board.?
The capacitance and voltage rating of the GIANT capacitor ?
Are there are 2 or 4 diodes at the end of the board near the P1-P2 AC input terminals of the PCB?
the issue is the 12 vdc that is avilable is way larger to fit in such the original one placeCan you remove transformer and replace with any 12Vdc supply to secondary pins? with correct polarity! with regards to caps.
yes we did..im trying to find a replacement for that part but i have problem for the available one's sizeDid anyone read #9?
