USB port dead, need ref on part
Tdenimal
Jan 25, 2025
4
Hello guys, on one of my electronic device the usb port completely dislocated.
Can you help me on finding the right reference as I need the exact same to fix it thank you very much
Martaine2005
May 12, 2015
5,299
A photo of the pins side may be useful too.
But as you have it, search ‘google’ for PCB mount USB A and then search images.
bertus
3,852
What you are showing is an empty shell.
Where is the rest of the usb connector?
Bertus
Tdenimal
Jan 25, 2025
4
It’s completely broken apart
Here how it was fixed on the PCB
Tdenimal
Jan 25, 2025
4
Sure it’s a regular PCB mounted female USB-A but I wasn’t to find the exact same fixation type as there is several way to weld a usb port to a PCB
Could be a bit tricky for a beginner to fit, even with the correct part.
Perhaps think about using an old usb lead and solder the cables direct to the 4 pins.
Delta Prime
Jul 29, 2020
2,989
The footprint or PCB solder pad dimensions are standardized.
I would recommend for you, a pre-soldered socket that is first attached to the PCB, and then the USB connector is plugged into the socket, offering easier replacement; easy peasy lemon squeezy…
