Need to know about this part
pharaon
Oct 28, 2014
458
What is the output of it0092b
Because it need to be replaced
Anon_LG
Jun 24, 2014
453
It appears to be a transformer, and this appears to be a power circuitry board. I can not find the datasheet through searching the ID characters, what product is your board from?
14,478
the SP2822 IC is a dual channel audio amp
the transformer is a mains stepdown transformer
how do you know it's faulty ? how did you test it ?
JimW
Oct 22, 2010
59
I will guess that the open winding is the primary. Most likely a thermal fuse that is open. These are right at the surface of the transformer windings. It would be much easier to replace this than find a replacement transformer with the correct size and pin spacing.
-Jim
73's de Edd
Aug 21, 2015
3,730
Sir pharaon . . . . .
Can you give us a photo of the flip flop / foil side of the board.?
The capacitance and voltage rating of the GIANT capacitor ?
Are there are 2 or 4 diodes at the end of the board near the P1-P2 AC input terminals of the PCB?
73's de Edd
I did a Google on SP2822 and came up with the following.
There is a circuit at the bottom showing the chip in a similar configuration with a 10v dc drive if that helps.
So I'm guessing transformer around 7vac output.
http://yaplog.jp/kazuikazui/archive/233
Your board looks like it has copped a fair bit of heat.
pharaon
Oct 28, 2014
458
here's the photo that show all
but if there's any electronic part rather than coils because i wont be able to find such small size so i wonder if there's an ic that do that same
the Big capacitor is 2200 uf 16 v
Sunnysky
Jul 15, 2016
573
Can you remove transformer and replace with any 12Vdc supply to secondary pins? with correct polarity! with regards to caps.
shrtrnd
Jan 15, 2010
3,903
If you've got the troubleshooting skills, if you find a transformer you think will work, I'd check those caps and bridge rectifier diodes before I tried to fire it up again. If your transformer burned open-circuit, it may have taken-out more
than just the transformer. Good luck with the transformer search.
Ok...thanks
Circuit attached.
pharaon
Oct 28, 2014
458
the issue is the 12 vdc that is avilable is way larger to fit in such the original one place
