Hi everyone,
Hey guys. Looking for some help with an oven that doesn't work. I have tried to get help elsewhere but the problem still persists no matter what I try. Any help or suggestions would be much appreciated.
I have an AEG competence b1180-4 (Pnc= 944 185 042) which was working fine for a couple of years before two days ago it stopped working.
When I switch it on at the wall socket the clock lights up and displays the time set function (which it never used to do) prompting me to set the time. After this if the oven is switched to one of the cooking modes (Grill, fan etc) the little red light on the left lights up as expected (however is sometimes flickering). However when the temperature dial is set the other red light (to tell if it has reached the set temperature) does not come on as expected and the oven does not start heating up. The main fan does not come on (however the cooling fan can be heard switching on an off intermittently). The grill does not heat up on that setting and the light inside does not come on.
I have tried the following:
1. Bypassed the clock entirely and the exact problem still persists.
2. Bypassed the little thermostat near the fan
3. bypassed the ZN limiter
Still the exact same problem...
The selector switch looks ok from the outside.
A more detailed description of what I have done and the help I have received so far along with photos can be found in this forum post.
http://www.ukwhitegoods.co.uk/forumsphpbb3/aeg-oven-not-working-correctly-t93969-15.html
Thanks for any help in advance
