Oven not working as expected.
Mymla
May 4, 2015
37
Hi everyone,
Hey guys. Looking for some help with an oven that doesn't work. I have tried to get help elsewhere but the problem still persists no matter what I try. Any help or suggestions would be much appreciated.
I have an AEG competence b1180-4 (Pnc= 944 185 042) which was working fine for a couple of years before two days ago it stopped working.
When I switch it on at the wall socket the clock lights up and displays the time set function (which it never used to do) prompting me to set the time. After this if the oven is switched to one of the cooking modes (Grill, fan etc) the little red light on the left lights up as expected (however is sometimes flickering). However when the temperature dial is set the other red light (to tell if it has reached the set temperature) does not come on as expected and the oven does not start heating up. The main fan does not come on (however the cooling fan can be heard switching on an off intermittently). The grill does not heat up on that setting and the light inside does not come on.
I have tried the following:
1. Bypassed the clock entirely and the exact problem still persists.
2. Bypassed the little thermostat near the fan
3. bypassed the ZN limiter
Still the exact same problem...
The selector switch looks ok from the outside.
A more detailed description of what I have done and the help I have received so far along with photos can be found in this forum post.
http://www.ukwhitegoods.co.uk/forumsphpbb3/aeg-oven-not-working-correctly-t93969-15.html
Thanks for any help in advance
davenn
14,470
dunno what that is ???
if it isn't the main rheostat, then you should be replacing the rheostat ....
I don't know who/what on that other place you are since I didn't see your nickname there ???
I did see a link to one pic that showed an overheated/burnt wire in a termination .... if that is yours, have you fixed that ?
Minder
Apr 24, 2015
3,561
On recent repairs to both full size ovens and toaster ovens, it has been a small relay that switches the elements on, they are small PCCT relays that are Supposed to carry the required current but I am not surprised they failed in light of the size.
A possibility.
M.
Mymla
May 4, 2015
37
Thanks for replying guys!
Davenn: The Zn limiter according to that website is the small blue rubber thing that was burnt. Bypassed it but same issue. By rheostat, do you mean the temperature setting knob? Sorry I'm new to oven mechanics. I'm Steve on the other site by the way.
Minder: where might I locate that relay and how would I know if it has gone.
davenn
14,470
never ever seen those in ovens
Mymla
May 4, 2015
37
Would there be a safe way to temporarily bypass that to see it it is the culprit?
Mymla
May 4, 2015
37
If I just join the wires going into it then does that just mean its set to maximum temp? That would do to test it. Once I know what's causing it I'll buy a new one
davenn
14,470
yes
so just leave it connected long enough to see that the element is warming up
Mymla
May 4, 2015
37
Tried bypassing that rheostat (temp dial) but still no joy. Such a weird problem. The only thing left I haven't tried is the selector switch but that has so many wires going into it i'm afraid to try and bypass it.
Minder
Apr 24, 2015
3,561
I would wager that is also a relay somewhere, the alternative switching device would be a SSR and so far they are few and far between that I have seen.
On most they are on the timer/clock/setting panel.
M.
Mymla
May 4, 2015
37
I have bypassed the clock so I can't be anything there. Pretty much everything is bypassed now except for the selector switch which looks ok on the outside but maybe it could be worn out on the inside
Minder
Apr 24, 2015
3,561
Can you see any printed circuit board behind the top panel?
Is there any small PCCT relays visible?
Usually small black or white cubes.
M.
Mymla
May 4, 2015
37
Behind the top panel as in where the clock is? or towards the back?
Thanks for the help!
Minder
Apr 24, 2015
3,561
I am not familiar with that particular oven, but it has been my experience the CCT board is behind the top panel shown with a clock/timer etc.
M.
