Please help me through diff equation questions
shaneyj
Jun 10, 2017
24
Can someone help me to get started...
Problem:
dy/dt + 2y(t) = 2x(t) where x(t) = u(t) and y(0) = -1
I know the standard form of a diff eq is:
dy/dx+ P(x)y=Q(x)
and I know how to solve for y using the integrating factor if the equation is in the same model as the standard equation
The issue I am having in the given problem: it is not in the form of the standard equation.
I don't see that 2y(t) is = to P(x)y.
And beyond that, I am unclear on where to plug in the givens
Any help would be appreciated.
I've attached a PDF if that helps
  • Differential_eqn_questions.pdf
Ratch
Mar 10, 2013
1,102
Problem:
dy/dx+ P(x)y=Q(x)
OK, x(t) = u(t) , which is the unit step function. For t > 0, you have to solve the DE dy/dt + 2y(t) = 2 with the given condition. For t < 0, you have to solve the DE dy/dt + 2y(t) = 0 with the given condition. Looks like the separation of variables method will work. Ask if you have any more probs.
Ratch
shaneyj
Jun 10, 2017
24
Ratch
Thank you, Ratch.
Why is it that for t greater than zero the DE is equal to 2?
Ratch
Mar 10, 2013
1,102
Thank you, Ratch.
The unit step function u(t) is 0 when t < 0 and 1 when t > 0 . Therefore, if x(t) = u(t), 2 x(t) = 2 when t > 0 and 0 when t< 0. So you have to solve the DE twice for each range of t.
Ratch
shaneyj
Jun 10, 2017
24
Ratch
I get that...
I solved and get y= 1/2 + C/2e^2t
So for y(0)=-1, should I set the equation equal to -1, plug in 0 for the t value, and find C?
Then set the equation = 0 and 2, like you originally indicated, and find t for those?
Am I correct in thinking that once I find C that value will be constant for all values of y, or does it change?
Ratch
Mar 10, 2013
1,102
I get that...
You are going to have to learn how to do this, or you won't get very far in DE.
Ratch
shaneyj
Jun 10, 2017
24
Ratch
That's great. Thank you. I'm going to work it with that method.
Our text says to use the method where e raised to the integral of P(x) (the integrating factor) is multiplied on both sides of the equation which is supposed to leave the IF times the y term equal to the other side times the IF.
That's where I got my answer.
It's been almost 2 years since I took calculus. I do need a refresher.
Ratch
Mar 10, 2013
1,102
Here is the solution using an integrating factor. You can't fool Mother Math, the solution will be the same.
Ratch
