Another problem. P1 is supposed to feed 0V to 11.2V to pin 3 of U2 (measure it) and U2 has a voltage gain of about 2.7 times so its output should go from 0V to about +30V. But if the LED lights then the input of U2 is reduced by U3 driving D9. Then the U3 problem with its pin 2 voltage being too high is not fixed.Installed new U2
R12/C6 connected to pin6 of u2
Adjusting P1 causes voltage on pin 6 to go from 0 to 7V
It is a good idea to replace all the cheap Chinese junk (Bangnogood).Got no spare C8's. Looking at replacing all original components supplied by banggood.
The output of U2 is its pin 6 that should be 2.7V higher than its input pin 3: 0V in = 0V out. 2V in= 5.4V out. 10V in= 27V out. 11.2V in (max)= 30V out.With R12/C6 connected to pin 6 of U2 where do I measure output voltage?
Pin 3 of U2 is fed through R8 and R9 from the slider of the voltage setting pot P1. It should go from 0V to 11.2V as the pot is turned but it is probably wrongly clamped through D9 by whatever is affecting U3. C4 might have the same leakage problem as C8. Disconnect D9 to see if U2 works properly without D9. If not then also disconnect C4.Pin 3 of U2 has got virtually no voltage on it - not stable.
That was needed to test U2 by itself.Oh, and I still have R12/C6 connected to pin 6
First, you need to fix whatever is causing the voltage on pin 2 of U3 to be a positive voltage higher than almost 0V.So can I reconnect safely?
