Triac Problem
Abdullah Badarneh
Feb 26, 2018
3
Hi,
I'm tired of trying search about this problem, and I didn't find any topic help me,
I made a circuit as in this image with keeping terminal 3 disconnected,
https://www.dropbox.com/s/xoxt8i2sheqcty0/Triac Problem.png
the problem is the lamp is flickering once I put/remove the plug in/from the power socket, as in this video
https://www.dropbox.com/s/xahbzf2li6c5su0/Triac Problem.mp4
I tried with two another triac bt136&bt138, but the same problem occured, any one can help me?
Thank you in advance.
Is that an LED bulb? What happens if you use a regular filament bulb?
What are you trying to do? Do you intend to connect something to the gate later on?
Is there anything connected to the gate now? Even just a wire that's not connected to anything else?
Abdullah Badarneh
Feb 26, 2018
3
I don't know,but I think it's filament bulb, I will be sure when I back to home, thank you for this note.
I tried to to control AC by connecting the triac with arduino using moc3021, but the problem occurs whether I connect the triac with moc3021 or disconnect it.
no, it's not connected with anything
I suspect it's a LED bulb and that leakage through the TRIAC charges up a capacitor in the bulb until it turns on briefly before repeating again and again.
You probably can't use a TRIAC to dim a LED bulb (especially if it's behaving how I suggest above).
Abdullah Badarneh
Feb 26, 2018
3
the trigger occurs regardless the type of device, I tried to connect Samsung charger that connected to phone, the same problem occurred
A Samsung charger is likely to be a switch mode device, and as such it may be very similar to a LED bulb.
At this point we haven't established whether the problem is due to leakage or false triggering of the TRIAC.
I have checked and these TRIACs are sensitive gate devices, so false triggering is a higher probability.
Assuming it is false triggering, a snubber across the TRIAC (a resistor in series with a capacitor across the MT1 and MT2 terminals) should help stop dv/dt triggering. However this will also increase leakage which may increase the problems for LED bulbs. Of the top of my head, a 47Ω resistor in series with a 0.1μF cap may be ok. Ensure the capacitor is mains rated.
A resistor between the gate and MT1 may reduce false triggering caused by any signals being coupled to the gate. Try a 4k7 resistor.
