Hello, can somebody help wich transistor is like bfg520
michael1978
Mar 17, 2012
388
It will not work. I told you and showed you:
1) L1 must be parallel with its tuning varactor but instead it is wrongly in series with it.
2) The value of C1 is 1 million times too much at 220uF and instead should be 220pF.
i make also parallel, but no success
Audioguru
Sep 24, 2016
3,656
Please post the schematic with parts values and a photo of the last circuit that did not work.
WHONOES
May 20, 2017
1,242
Hi again. See attached my version of your oscillator which does work. Simulated using Simetrix.
To actually make this sort of simulation work, you often need a perturbation of some sort to initiate oscillation. That is what the extra bits "V2 and C5" are for. They combine to give a very short pulse at the junction of C3 and L1. To set the pulse from V2, right click it and then set up as in the third attachment "Set V2".png.
To get best sine wave resolution, click on "Simulator" on the menu bar, make sure "Transient" is selected, click on "Advanced Options" at the bottom of the window the in the next window, set "Max Time Step" to 50p then close that window.
Now simulate and you should get the same results as me.
  • RF Colpitts osc.pdf
  • RF Colpitts Osc Graph.pdf
Audioguru
Sep 24, 2016
3,656
C1 is an electrolytic capacitor that has too much inductance for it to work at the high radio frequency.
michael1978
Mar 17, 2012
388
what to do? can you tell wich value to set to capacitors and i wanna try please, do you rembmember you said in parallell
michael1978
Mar 17, 2012
388
Thank you a loottts for time and help thanks
michael1978
Mar 17, 2012
388
Hello sir, i make min, but i dont know why i dontt get wavefrome like yourss? and idea, is nice software i like it
WHONOES
May 20, 2017
1,242
is working so
I change 220p 220p
do you know why i cant get clear waveform sine?
Did you set all the component values as in my schematic? including the transistors?
Also, the circuit needs R4 which is effectively the DC resistance of L1. Without it the simulator will regard L1 as a perfect inductor and it will have a very high Q.
Attach a copy of your simulation circuit to your next post. Save it as a PDF and attach as such.
michael1978
Mar 17, 2012
388
I can give you my file if you want, but the valuse are the same like in begin, but i make it yours is working perfect
if i make bf199 than i get this one , maybe i confige bad the simulator, can you do something? thanks4.png
WHONOES
May 20, 2017
1,242
if i make bf199 than i get this one , maybe i confige bad the simulator, can you do something? thanksView attachment 42320
First off, I can't see your circuit behind the graph which you have superimposed over the schematic. Second, R4 is not the correct value, it should be 390R. Third, the filter will be loading the O/P stage causing the distortion that you see.
Please save schematic and graph separately as PDF's, you can do that from the file menu, and sent both of them.
Audioguru
Sep 24, 2016
3,656
How should he fix his broken spelling and broken grammar??
Maybe his translation software is broken?
michael1978
Mar 17, 2012
388
can i send you the file better, my version is 7.2 OF SIMETRIX
michael1978
Mar 17, 2012
388
Here is complete schematic 1.RAR you need winrar to uuzip
  • 1.rar
michael1978
Mar 17, 2012
388
Hey man is working i change R4 is perfect sinewave. Thanks a lotttttttttt for taken so much time from you peace
