Hello, can somebody help wich transistor is like bfg520
Audioguru
Sep 24, 2016
3,656
Please post a schematic of the output of the radio connected to your LM386 circuit and fix the problems:
Audioguru
Sep 24, 2016
3,656
Yes, you make the same errors over and over and over and over and …..
I like your huge 0.01 Farads capacitors. They will kill all output sounds.
Why are the transistors powered from only 0.5 somethings?
michael1978
Mar 17, 2012
388
Yes you right i make some version i must be 0.01µ, AND THE BATTERY 2V, but my problem is now i take from a book, the autput should be from C4, but i dont receive sine wave, why man, now detector is okey why i dont receive sine wave, can you help a little bit, what is wrong, why i don receive sinewave
Audioguru
Sep 24, 2016
3,656
Which battery is 2V? V3? It is shorted to ground on your mess of a schematic.
I asked you to post how you connected the output of the discriminator to the LM386 amplifier and show all the details of your LM386 amplifier but you do not show them.
michael1978
Mar 17, 2012
388
Thanks but i build one with lm386 TO YOU WANT TO SHOW? but you you said is not correct the detector, rely i mean i make it like in foto, i with show you the file
michael1978
Mar 17, 2012
388
IS this one good detector, I DONT KNOW HOW TO CONNECT THE LM386, when i am nt sure he demulate the signal, look i put to inductor plarity, tell me please, where is the problem2.png
Audioguru
Sep 24, 2016
3,656
1) V3 is 0.5 "somethings" again then the transistors have no power supply and they will do nothing.
2) The base of Q1 is shorted to +12V again.
3) The coils on the transformers are missing the polarity dots again.
4) C4 is not connected to ground again.
5) The radio is not connected to the LM386 (look at C15).
6) The audio frequency is way too high at 1MHz.
7) D2, R2 and C5 are not connected to ground.
8) The value of R10 is so low that it is shorting most of the audio, you do not need R10, remove it.
9) You also do not need C15, R8 and C9, remove them.
10) The input of the LM386 needs a volume control.
11) The LM386 has no pin numbers so it will not work.
12) C10 blocks DC powering the LM386 so it is not powered and will not work.
13) Why doesn't the LM386 use the same +12V as the radio?
14) Remove R6.
Why do you make so many mistakes?
Audioguru
Sep 24, 2016
3,656
You added the LM386 to an old radio schematic that was full of errors. The new schematic still has most of the old errors.
On the radio, Q1 is not powered by anything and is not connected to L1.
michael1978
Mar 17, 2012
388
LOOK i MAKE a new version of detector like in book, what you can say about this, is this fm detector in orde, after i gonna connected lm386 LIKE YOU SHOW ME?, IS ORGINAL FROM BOOK? IF THEY HAVE ERROR LIKE BOTTOM A I WILL FIX NO PROBLEM, I JUST ONE TO SHOW NEW VERSION AND TO WORK IN THIS VERSION? THANKS
michael1978
Mar 17, 2012
388
i change asomething but, now is not getting signal from R10 on the right LINE, what to d2.png o now
michael1978
Mar 17, 2012
388
Audiguru i am whaiting from you, i changes, now what i have to do, and also signal is output from C5
Audioguru
Sep 24, 2016
3,656
More mistakes:
1) Q1 is not powered since L1 shorts the DC from R5 to ground. R5 and maybe L1 will burn up.
2) V3 is not needed.
3) Why do you have R10? It is shorting most mid and low audio frequencies to ground because it is calculated wrongly and it is not needed.
4) C4 is not connected to ground.
5) You have the audio that feeds C8 grounded so there will be no sound.
6) You have the audio frequency way too high at 80kHz.
The schematic of the LM386 amplifier is shown in its datasheet. It uses a 10k volume control so C8 that feeds it should be 0.33uF.
michael1978
Mar 17, 2012
388
More mistakes:
This is my last version in change a lot, but i dont understand how to put C4 to gorund can you help i dont know(i know to put a simbol of ground) but i dont understand you, please help
Audioguru
Sep 24, 2016
3,656
You did not fix the problems:
1) Q1 is still not powered.
3) R10 is not needed in parallel and is not needed in series.
5) There are still no pin numbers on the LM386 amplifier.
6) C10 is still blocking the DC power to the LM386 amplifier.
New problems:
1) The audio is now a radio frequency in the AM broadcast band (600kHz).
2) There is no volume control.
3) R10 is not needed.
Audioguru
Sep 24, 2016
3,656
You changed the audio frequency to 1MHz which is not audio.
Q1 and the LM386 are not powered.
The value of C14 is one million times too small.
Try C4 both ways:
michael1978
Mar 17, 2012
388
Try C4 both ways:
AND WHAT TO TO POWER IT MANUAM? WITH RESISTOR FOR EXAMPLE MIN AND MAX?, I CHANGE THE VALU OF C4, THNX MAN, I TRY IS NOT WORKING HOW TO POWER LM386 AND Q1
