My boats central heating is controlled by a small Johnson 24 volt magnetic drive circulating pump. The speed of the pump is controlled by a pwm with attached thermistor fastened to the boiler outlet pipe.
A week or so ago the pump speed went a bit haywire then the motor stopped. I traced the fault to the pump area.
Immediately before the pump, on the positive wire, is a small rubber component that looks like a bullet type connector block. When I touched it the motor sprang back to life. I thought it was a connector block with a bad connection. In fact, inside the rubber on the positive wire is a coiled tube of bright copper wire. I didn't't disturb it as it appeared to work OK again.
Early this morning the fault returned.
What is the component, and would it be safe to remove it completely?
The pump is very low amperage and of the circulating type, not a pressure pump.
Many thanks, Stu
Many thanks, Stu
