Short story: I’ve been googling this and have also contacted customer service a Mouser Electronics and have not been able to find this capacitor. Can anyone point me in the right direction, or recommend a suitable replacement?
Long story: Trying to repair a 1950’s Westinghouse mixer. The variable speed control doesn’t work, it only runs at full speed. Inside I found the large ceramic 300Ω 30w resistor that’s part of the speed control had snapped in half. I replaced it with a Caddock Thick Film Resistor 300Ω 30W I found online at Mouser Electronics, but there was no change in operation. That leaves the capacitor
When searching for the .5 MFD / 300 VDC I found someone who makes replacement capacitors for vintage Sunbeam mixers. He told me that his 0.1 uf / 600 VAC capacitor should work. I installed it and the bit of smoke I saw lead me to believe that I blew the new resistor I installed. The speed control now works roughly with the contacts that make up the mechanical part of speed control vibrating audibly. I’ve read that running it this way will eventually burn up the contacts, though.
Thanks in advance for your help.
