Questions lithium polymer battery
Status
Not open for further replies.
gamer87
Mar 11, 2017
261
I own an electronic equipment uses 2000mA lithium polymer battery but I use this equipment rarely it is stored unused for months and years and I wanted to conserve this lithium polymer battery so that its maximum capacity and recharge does not fall to 1800mAh and it goes down, it was built to recharge 2000mah and I want to keep 2000mah of maximum recharge and I don't want to miss the recharge cycles of this battery
Bluejets
Oct 5, 2014
7,374
Getting the most out of lithium batteries usually means storing at around half capacity.
Then when required, the battery is cycled and recharged to maximum.
It depends on the source / quality of the battery in question but I doubt you will ever get full capacity.
Storing for months might be ok but years...?? I don't think any will last that long.
Check battery university online for recommendations.
Audioguru
Sep 24, 2016
3,656
I agree to store a Li-PO battery at 3.7V per cell.
I store the Li-PO batteries for my RC airplanes at the half-charged voltage every winter and they last for years.
I have the Li-ion battery from my daughter's first cell phone. It has been at half-charge for 22 years and still works fine.
gamer87
Mar 11, 2017
261
What tips did you follow to make the lithium polymer battery last 22 years?
Audioguru
Sep 24, 2016
3,656
I told you that "It has been at half-charge for 22 years".
Also it was never made too hot.
Also it did not have thousands of charge-discharge cycles.
gamer87
Mar 11, 2017
261
i need information storage conserve battery lithium polymer long time no use
Bluejets
Oct 5, 2014
7,374
So not a Turnigy or similar 2200 3 cell for $18.00 then....:)
gamer87
Mar 11, 2017
261
Store the lithium polymer battery with some no 0% charge is the best tip for conserving and preserving the battery as much as possible?
Bluejets
Oct 5, 2014
7,374
0% charge means a dead lipo.
Don't read the recommended minimum voltage recommendations then..??
Audioguru
Sep 24, 2016
3,656
Turnigy is Hobby King junk from China. My friend bought 10 Turnigy batteries but only 2 of them worked. The newer Nanotech batteries are improved.
Bluejets
Oct 5, 2014
7,374
Appreciate the recommendation.
I just wondered which brand you managed to get 22 years from without it puffing up like a blowfish.
Audioguru
Sep 24, 2016
3,656
Just now, I entered here and saw the Batteryuniversity Warnings Table that I did not see yesterday so I went there. It gave me a warning that my pc has a virus and that that Norton (I don't have Norton) will delete all my files. Microsoft Defender anti-virus software that I use says my pc is fine.
The 22 years old Li-Ion battery is Sanyo and has two AA size cells in metal cases with cardboard sleeves on top, spot-welded in parallel. The battery plastic case has a Sanyo label but the battery cells have no label. Today they measure 3.55V.
Many places, even Walmart still sell no-name-brand replacements for this battery.
Bluejets
Oct 5, 2014
7,374
Ahha.....not lipo's then.
Yes, I have seen Sanyo nicads last extremely long periods.
Back in the 80's when flying RC aircraft, it was a common practice to chuck out the nicads after 2 years. They were relatively cheap then and 2 years of cycling would see a slight depreciation but not too much.
Still, the aircraft at the time had a lot invested in them in terms of time and money.
Therefore, come the 2 year old point and chuck 'em.
Near fell over when I saw the flying instructor still using the same batteries after 7 years especially since they really copped a flogging.
BUT, seemed to work out ok.
Dodgy trainer lead used to create more fizzy moments than batteries ever did. :):)
Tend to go to Eneloops now.
Audioguru
Sep 24, 2016
3,656
There is no way that an old Ni-Cad cell is 3.55V. Besides, a Ni-Cad cell could hold a charge for 2 months if you are lucky.
I looked up the Sanyo battery number in Google and any battery retailers have lithium replacements.
Status
