Your build looks good. Nice and neat. If required, you could reduce the pulse width by reducing the value of R3 to 12 or 10K. But if the pulse width is OK as is then I would leave it alone. I don't know if the actual pulse width has any effect on the apparent ignition timing. If the timing is taken from the leading edge of the pulse, which seems most likely, then within reason, the pulse width is not very important so long as it is not so long that it turns into a continuous pulse at high RPM.
