Hi all,
I have the circuit connected below, I am using the following AQY222R2T MOS Relay. Basically I am using the MOS relay to switch an output of 10V @ 400mA. The device is AQY222R2TY
I have worked out the input resistor as
R = Vin - VF
IF
From the datasheet this works out as
10V - 1.05V
------------ = 1.79K or 1.8K
5mA
I have a few questions:
1. Is my calculation for R correct? I have used the following (drop out voltage waveform diagram 7 in the datasheet i.e. at 5mA the VF is around 1.05V). Or should I be using 3mA (led operate current) instead of 5mA?
2. The Output power is rated at 250mW, I believe that my output of 10V @ 400mA = 400mW - hence the device is not suitable.
3. The FET used to switch the FET led has a RDS max of 3R, which I can add to the calculation, but is that really going to matter.
4. I can't see a max input voltage, so will the 10V be ok?
Finally will a G3VM-63G be a better choice? This has an output capability of 500mA @ 60V. I can't however see the output power dissipation of this device.
Any help would be appreciated.
R = Vin - VF
IF
10V - 1.05V
5mA
