How can I fix an unformattable raw micro SD card?
TheuTrich
Nov 17, 2021
14
I have an 8GB micro SD card. I have tried all card readers and it doesn't help, I change to another computer and still does not help.
-Micro SD card is now RAW Format and “The volume does not contain a recognized file system.”
-I had used the digital camera to format and it did not work.
-I use normal format it says “Windows was unable to complete the format.”
-Format in Disk Management said “The format did not complete successfully”
-In DiskPart format will say “DiskPart has encountered an error: The parameter is incorrect.
See the System Event Log for more information.”
-Even sfc /scannow didn’t work.
I hope this is enough information. Thank you.
TheuTrich
Nov 17, 2021
14
Get a new one. This one is defect. And iven if you could "repair" it, you shouldn't trust it to hold any data safely.
Thanks for your reply!. I know this can be hard but I think there is still a way to repair it and I don't care much about data I just want to fix it
John Canon
Jun 1, 2022
91
Since you are experimenting try this. Fold a paper towel with the SD card on top and place it in the freezer for 1 hour. Remove it, dry it off with a microfiber cloth quickly and place it in your favorite formatting device. Be quick ... then format ... maybe.
Bluejets
Oct 5, 2014
7,374
I've heard everything now.
Nope....have now though......:rolleyes:
TheuTrich
Nov 17, 2021
14
Thanks for your suggestion, but my sd card is still not able to format. :(
John Canon
Jun 1, 2022
91
Since you are experimenting try this. Place the SD card on a plate and microwave it for 1 second. Stand back and keep a fire extinguisher handy. Then place it in your favorite formatting device. If nothing then dip it in some honey and place it in the garbage bin.
bertus
3,835
Hello,
The microwave oven is a perfect way for permanent distruction of the SD card
It will be unusable in any way
Bertus
bertus
3,835
Hello,
Have you used an other reader/writer for the card?
Have you tried an other operating system?
With Knoppix, you can try to access the card in linux.
http://knoppix.net/
It is a "live" distribution that will boot-up from a DVD.
An other bootable CD is Hiren's boot CD.
It is windows based, packed with all kinds of tools:
https://www.hirensbootcd.org/
You can also install them on USB sticks.
Bertus
Martaine2005
May 12, 2015
5,276
Have you got an old (er) computer running XP? You can try formatting to FAT32.
This has saved me dozens of times.
Martin
