Bench power supply upgrade
My ancient Heathkit bench supply died a while ago so I bought one of the 30V 3A variable power supply kits like the link below that are all over eBay to replace/upgrade the insides of it with.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,968
So now I have 30 of them.
Too bad, since you purchased from China, that you have no idea what those 30 "devices" really are. Finding out "fer sure" would cost more... much more... than what you would have spent purchasing from a North American distributor the original lot of 10. But, hey, ya pays yer money and ya makes your choices. I have bought electronics stuff from China, mostly through Amazon. Once I tried to purchase via email exchange for a project that used stepper motors. I have had no problems with Amazon, but there was a huge language problem trying to communicate, both verbally and through documents, with the Chinese. I finally gave up trying to source a motor from China when the person I was trying to buy these motor for decided to purchase them himself.
Still waiting for those motors so I can continue with that, now almost ten-year old, project. Both he and I are getting older, so it may never get finished, but if it does, I will send a link to where you can purchase one... of the stepper motors that is. Cannot say how the motors will be used, because of an NDA I signed for the person who wants the motors.
I need to take some time now to go back and read the whole thread of dialog between you and AudioGuru. If I recall correctly, he was the person who first discovered, and then reported to this forum all those problems in the Asian power supply... not only discovered but also explained and corrected! If it wasn't this thread (which is old) it might be a very much older thread. Whatever... what I need to know now is the final corrected schematic with parts identified by symbol and value. I guess a BOM (Bill of Materials) would be a little much to ask?
when I get a chance I'll refresh my memory about this and test some of them to see if they have the appropriate resistance between the offset pins.
You might as well test them for functionality, too. Some, all, or none of them may be parts actually manufactured by Texas Instruments.
A small ZIF or Zero Insertion Force socket would speed up the testing process. Functionality testing can get complicated really fast. Testing just the two "offset" pins for resistance and rejecting those devices that show "no continuity" is just a minimum test to sort bad from possibly good. Even a "bad" chip could turn out to be "good" if only you knew more about it. And all the "possibly good" devices that "pass" the continuity test could be fakes or defective. However, I think you can now purchase a "smart socket" instrument that analyzes whatever device you insert into it and then tells you the nearest equivalent part number. IIRC, it was a bit pricey... maybe needed a cloud-based database to store specs for every integrated circuit or device it recognized.
Maybe I should use this website's "search function" instead of cluttering us space on your screen!
Sidecar Bob
Dec 19, 2021
268
You completely miss the point of what I'm doing here. There is pleasure to be found in doing something without spending any more money than necessary and buying from a North American seller would have meant paying more for shipping than the parts are worth.
I have been updating the schematic every time I make changes and if/when the project is complete I will post a final version with a list of all of the changes.
This thread was only started 8 months ago. Considering that it is a discussion about an ongoing project (that is on hold while the weather is nice enough to work in the garden and the garage workshop - electronics is primarily a winter activity for me), and that I posted an update just last week I wouldn't say this is an "old thread".
hevans1944
Hop - AC8NS
Jun 21, 2012
4,968
No, I don't think I missed the point. As I said, ya pays yer money and ya makes yer choices. I prefer not to waste my valuable time trying to use components of unknown origin or quality. It makes troubleshooting much more difficult if you cannot trust that ALL the parts function the way they were originally intended. That is just one of the reasons that I have instruments to measure resistance, capacitance, and inductance of passive components. And instruments to measure wave forms (oscilloscopes) and steady voltages and currents (digital and analog multi-meters).
For my amateur radio hobby, I would own an RF spectrum analyzer and a 2-port vector network analyzer (VNA) if I could afford them. My amateur radio rig has to date cost me upwards of 3000 USD with no end in sight for antennas, feed lines, lightning arresters, etc. It's an expensive hobby, even if you build from scratch. I did that when I got my Novice license in 1962: built the transmitter and its power supply from parts, but built the amateur radio receiver as a Heathkit SB-300. Current rig is an Elecraft KX3 with a 100 watt linear amplifier accessory. Can't use the amp because I have not put up a permanent working antenna here in Florida, the Lightning Capital of the United States. I do have a multi-band vertical that was given to me my a member of the Tamiami Amateur Radio Club here in Venice, but it needs some repairs and a mechanism to lower it to the ground when not in use, especially during thunderstorms.
In the 1970s, I was paying more for the socket than I paid for the integrated circuit that plugged into it. Pay more for shipping than the parts are worth? Ha. That cost is already "built in" to the selling price. My only point was that China is not, and may never have been, a reliable source of electronic components. They seem to be on the same path that plagued Japan after WWII: build cheap copies, but without quality control, and with no respect for intelluctual property rights. In Japan, that eventually changed, but I see no indication, or incentive, for such change in China's business practices.
As an amateur radio operator, or "ham," originally licensed in 1962, but an avid electronics enthusiast and experimenter since the early 1950s when I was living (temporarily) with my paternal grandparents while Mother recovered from tuberculosis of her lungs, I learned very early on how to "make do" with what I had on hand, or could reasonably scrounge from "stuff" thrown away in the alley behind radio and TV repair shops. Alas, consumer electronics is no longer considered "repairable" for profit, so we throw away the baby (television) with the bath water into a landfill. Not a nice place to scrounge for parts IMHO, but there are cheap (when they work) electronics available from Asia via Amazon and eBay. I don't always "buy American" to support my electronics hobby.
This thread was only started 8 months ago. Considering that it is a discussion about an ongoing project (that is on hold while the weather is nice h to work in the garden and the garage workshop - electronics is primarily a winter activity for me), and that I posted an update just last week I wouldn't say this is an "old thread".
I suppose "old" is relative. The thread I remember was much, much older than eight months ago. Here is a link to discussions involving @Audioguru that date back to 2017, almost ten years ago. We re-invent the wheel quite often here, mainly to accommodate new members who cannot be bothered to research anything. The most popular topics seem to revolve around LEDs and/or how to re-charge various batteries. Congratulations to you for trying something a little more sophisticated and perhaps challenging.
Apparently, like you, I am a "hands on" experimenter and hate to spend too much money for parts that I know can be obtained much cheaper overseas than in the North American continent, excluding Mexico whose government behaves like a third-world banana republic. Mexico could be our "China" here, close to home with a hard-working but lower paid population. However, for reasons of money, power, and/or corruption it isn't. So I mostly buy cheap, passive, Chinese parts from Amazon and hope for the best. At least with Amazon Prime I know something will be delivered and about when that will occur. And Amazon has a really nice return and refund or replace policy for most items. If I need some circuit boards made, I will probably try to purchase those from China too. Most PCB shops in the US have been legislated out of existence by unaffordable pollution-control polices, but I still know how to make my own single-sided copper boards. Just have to be careful when and where I dispose of the chemicals, so as not to contaminate my well water.:cool:
Sidecar Bob
Dec 19, 2021
268
Spending lots of money on your main hobby is one thing but for me electronics is primarily a means to an end (something I do to make things for my motorcycles and model trains and household projects) so it is far down the list of things I spend money on.
And in this case, a big part of the project is to re-learn a lot of the stuff I've forgotten since i was actively involved in electronics and learn about things that weren't invented in the 1980s. The issues I've had to deal with in this project have taught me a lot so even if I end up scrapping the Chinese board entirely it will have been worthwhile (although having seen videos of them working I can't see any reason that will be necessary).
Re cost of shipping vs value of items, the Canadian sources I checked wanted from [imath]8 to[/imath]20 for shipping, which is ridiculous compared to 3 lots from different sellers for a total of about $8 including shipping.
Re reliability of Chinese electronics, a lot of the consumer electronics we buy (including most brand name products) are made there so we know they can produce good, reliable parts (whether my Aliexpress bargains are close to that level is to be seen).
US vs Chinese quality? Let me tell you a story: A certain major US based manufacturer of model trains was known for producing locomotives that were noisy & jerky out of the box but could become really good runners if you replaced the factory applied grease with toothpaste and ran it in each direction for several hours to lap everything in before flushing out the toothpaste and re-lubricating.
When they moved production to China they made all of the parts to the same drawings and with the same materials but those locomotives run smoothly & quietly right out of the box.
Re old threads, I moderate on a couple of motorcycle forums and it isn't uncommon for newbies to revive threads 10-15 years old to ask someone who hasn't been on the forum for nearly that long about some detail of what they posted. That is old.
BTW: 2017 was only 5 years ago.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,968
Ooops! I really HATE getting older and forgetting how to do simple math. March 2017 was three months after we moved into our house in South Venice, FL. That's when my pacemaker/defibrillator started shocking me a
Sidecar Bob
Dec 19, 2021
268
I'm the opposite. I keep thinking that 2017 was just a couple of years ago.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,968
Hmmm. I HATE getting old and forgetting how to do simple arithmetic. Five years seems like eternity here in Paradise.
And I do sometimes read old threads, posted below threads like this one under the banner Similar threads. Don't often respond with a comment though, unless I forget to look at the posting dates. You are correct, there is a lot of good information in those older posts if you take the time to carefully read them and separate the "wheat" from the "chaff" and ignore the wild-ass speculation. Unfortunately my motorcycle riding days are over, but wife has shipped here, and had professionally restored, my Honda Shadow ACE 1100cc cruiser for my "last ride" ceremony with my ashes. Wife and I traveled far and wide on that bike the first few years we were married, but she says I can't ride anymore unless I convert to a trike. Too dangerous because of my heart conditions, other comorbidity, and age. But I can't afford a trike, or even an F-150E electric pickup truck.
At one time my brother and I "owned" an O-gauge, three-rail, AC motor-driven electric train set. Dad was a navigator/bombardier on B-47s working for the Strategic Air Command (SAC). The Government moved us around a lot, but the train set was always carefully disassembled and boxed before we moved. The last time I remember setting it up was in the attic of a rental house in Phoenixville, PA while Dad was at nearby Valley Forge Army Hospital recovering from tuberculosis of the kidneys.
The train set eventually wound up in Dayton, Ohio, after Dad retired. He had purchased a lot of rolling stock and accessories like electrified turnouts, signal lights, and a flat-car lumber un-loader, just to name a few. Once in a while he would show up for Christmas with a new locamotive, always a steam locamotive, never a diesel-electric. In Dayton, Dad was in the process of getting a divorce from our mom. I had joined the Air Force about that time and I was surprised to find out he had sold or given away to his American Legion "buddies" the entire train collection. I hope he found it to be a good return on his investment.
Please let us know how your Heathkit power supply restoration/upgrade turns out. I am thinking of attempting the same sort of thing using an AT switch-mode power supply as a bench power supply... plenty of "stuff" on the Internet on how (maybe) to do that.
Sidecar Bob
Dec 19, 2021
268
I model in HO scale. Most of mine run on variable DC but a few run on a form of AC... If you want to see some interesting electronics look up Digital Command Control.
The bike in the rear ('83 GL1100 with Dnepr sidecar) is what I drive in the summer and the one in front (originally an '83 CX650E with Velorex sidecar body on Ural frame) is what I drove it to work every day in the cold half of the year (it sees a lot less use since I retired).
I plan to continue as long as I am able to climb on ;-)
I may eventually build a fixed voltage supply from a computer PSU too if I think it will be useful. One of these (available for about $5) might be a good place to start
hevans1944
Hop - AC8NS
Jun 21, 2012
4,968
When my two boys and two girls were of the "right" ages to appreciate it, I began putting together a small HO layout. This would have been in the 1970s IIRC. Not a single one of them showed any interest in model railroading, much to my dismay, as I had an entire basement in which to build it... less room dedicated to laundry and storage and a Shopsmith woodworking shop and a cartridge re-loading bench.
I went ahead anyway and purchased a four-by-eight foot sheet of plywood and some two-by-four lumber to make a table to erect track on. Also read lots of model railroad magazines with their impressively realistic photos of layouts that other people, smarter, wealthier, and/or more committed than I, had published. I even was offered the opportunity to visit an organ recital that was conducted in a two-story brick building separate from the living quarters of the owner. Seems he was into restoring old church and theater pipe organs. And his side hobby was building model train layouts.
This visit was "by invitation only," but I had an acquaintance who was also interested in salvaging and restoring pipe organs, mostly from churches, and he invited me to accompany him. One of the things that I learned is the "pipes" you see behind the pulpit in a church organ are fake. The real sound takes place out of sight and the real sound-producing "instruments" look like junk, or at the very least cobbled together from random pieces. Fascinating, but disappointing to find out what was really "behind the curtain". It was about this time that electronics for consumers was really beginning to take off in a big way. IIRC, this applied in spades to model railroading. So, pulse-width-modulated, multiple engines each with remote speed and direction control from anywhere along the line became instantly possible and practical, albeit a bit pricey.
Today I looked at the 2022 Lionel online catalog. My, how things have changed! Of course, Lionel has retained their three-rail AC powered system but now have added HO gauge and LOTS of "bells and whistles" including Bluetooth and Voice remote control while still retaining the legacy system "controls" which offered forward, reverse, and stop with a limited range of speed control. I remember the legacy set my brother and I had set up in Phoenxiville, PA, experienced problems because the connecting pins that held the tracks together had became loose from all the moving the Air Force put our family through over a period of twenty years. Still, we had a lot of fun with it. Years later, after I had children of my own, I pined for an HO layout, but it took several years before I could afford to buy just a beginners set. Eventually my kids grew up and moved away and the train set disappeared. <sigh>
Ahh, Digital Command Control is described here. This may have been what I was reading about in the 1970s. And Lionel may not be selling their legacy three-rail AC system in HO gauge. It's a huge catalog and I haven't examined it in detail yet.
I admire the sidecars on your motorcycles. Maybe wife would let me ride again if I put one on my Honda... Nah, I would probably have to sit in the sidecar while she drove the bike, so that would be a non-starter for me. Of course I wouldn't need any rain gear like the driver would... it rains a LOT here in southwestern Florida because of moisture-laden air blowing in from the Gulf of Mexico. Up North, when we were riding together in tandem, we both had rain gear and visor helmets, but I would usually pull off the road and park under an overpass or under a bridge when a heavy rain caught up with us. Automobile drivers have a hard time seeing motorcycles even in broad daylight. Add in some rain and it gets to be real problem, so we get off the road.
The "breakout" terminals (from China!) for the ATX form-factor power supply looks interesting.
73 de AC8NS (Hop)
Sidecar Bob
Dec 19, 2021
268
I got my first motorcycle because I was getting tired of taking the bus to work. A friend at work attached a sidecar to his bike for winter; I couldn't afford a bike and a car and I preferred to have a bike so I decided to do the same. That was OK but I spent a lot of summer weekends fixing the damage winter did (it takes longer when you have to get it back together in time to drive to work Monday morning, then take things apart again next weekend) so when we could afford it I bought a 2nd bike and changed the license plate and insurance over in the spring & fall.
Several decades later they closed the paved road I used to get to work to replace a couple of bridges so I started taking one of the dirt/gravel roads that I normally didn't take on 2 wheels and realized how much better the scenery there was than going through town so I convinced my wife that I should get a 2nd sidecar and the outfit in my avatar pic was born.
The only thing I don't like about having a sidecar is that I never get to ride in it myself ;)
If you think Lionel has come a long way since the '70s have a look at some of the stuff Rapido Trains is making. In addition to DCC with sound and underbody detail like this the interiors of the passenger cars have the correct colours for everything, right down to the tablecloths and plates in the dining cars.
http://www.wig-wag-trains.com/Rapido/Pictures/Undebody.JPG
Sidecar Bob
Dec 19, 2021
268
3 years have gone by and I have finally come back to this project.
The first thing I did was look up how to test whether or not the 3 batches of "TL081" ICs that I bought have the offset circuitry; You simply measure the resistance between pin 1 and pin 5, looking for something in the 2K ohm range.
One batch came loose in a little ziplock bag, the 2nd batch with their pins pushed into a piece of pink foam (also in a ziplock) and the 3rd batch are in an IC tube. It was not very surprising that the only ones that passed were the ones in the tube.
I had installed IC sockets in place of the original ICs before I put the project aside so I plugged 3 new chips into them, turned it on and attempted to adjust the offset null. Turning R7 had very little effect. And when I turned the voltage pot up the voltage didn't increase.
I suspect that when the 2nd fake TL081 failed it took something else with it.
I couldn't see anything obvious but I will take another look at it this afternoon.
BUT I recently found this video about building a variable bench power supply with a commonly available LTC3780 buck/boost module. This looks like it might produce a better supply than the "red kit" could. And he used a switching power supply very similar to the one I am trying to use.
I have almost convinced myself to scrap the kit and order an LTC3780 module.
What do you think?
Sidecar Bob
Dec 19, 2021
268
My big doubt about using an LTC3780 was that all of the bench power supply builds I could find that used it are from 6-8 years ago with nothing recent, which means that either all that needed to be said had been or something better came long that everyone started using (& talking about) instead.
I did more research today and figured out that they started using buck/boost converter modules that are designed to be variable power supplies.
So I shopped around and ordered an SK60 module for about what the LTC3780 and the linear pots would have cost.
https://www.aliexpress.com/item/1005007309288430.html
In my particular case (changing in mid project), using an LTC3780 would have meant that the front panel layout could stay the same.
With the SK60 I won't need the holes for the voltage and current controls or the overcurrent light and I'll probably have to enlarge the hole for the volt & amp meter to fit the new module but I'll figure it out and the end result will be a lot simpler.
Sidecar Bob
Dec 19, 2021
268
That didn't last long. On Friday Mar 28 a major ice storm moved into Southern Ontario. The weight of the ice damaged a lot of trees and that took out power lines everywhere. We were without power from Friday until Wednesday (5 days). With no power our sump pump didn't work so by Sunday morning there was about 2" of water above the raised basement floor (4" total).
When he heard we were flooded our neighbour's son brought us his generator but the damage had been done by then.
When the power came back and our local post office opened the SK60 module had arrived but the shop where I work on electronics is in the basement so I won't be able to do anything like that until the water damaged floor is replaced.
Here are a few pictures of our yard on Sunday March 30
hevans1944
Hop - AC8NS
Jun 21, 2012
4,968
It's almost winter again. Are you still on this forum? How goes your power supply project?
Sidecar Bob
Dec 19, 2021
268
I'm still on the forum but I haven't been active.
Dealing with the aftermath of the flood is taking a lot longer than I had hoped. Around the time I last posted we had a "mini bin" (14 yards) on our driveway for the stuff that couldn't be saved and a 20 foot shipping container for the stuff that wasn't damaged. The container is still there and will be for the foreseeable future.
We also filled most of the garage; With no space and no time to work on the summer bike (the sidecar outfit in my avatar pic) I left the winter one on the road all summer.
Once we had moved everything out of the basement that we could a remediation crew came to remove the raised floors (1/2" plywood on 2x2s) and the drywall on the lower part of all the walls and spray for mould. They found cracks in the foundation so I had to hire someone to repair that.
I started putting the basement back together in early August but I'm working on my own and I've decided it makes sense to make most of the improvements I've always wanted to while things are already apart so it isn't exactly progressing quickly. I won't bore you with all of the renovation details but as of last week I have the bathroom, the shop and 2 other rooms basically done (I'll come back for details like painting doors and window frames after everything else is finished).
One of those is a storage room so we were finally able to empty my parking space and after 6 months on the driveway I could finally start parking the outfit inside again, just in time for the snow.
The renovations have to take priority over hobbies so who knows when I'll get back to working on electronics. The good news is that when I do the shop will be a nicer place to spend time in.
The last room I'll put back together is the model train room. I've been talking about tearing out the old layout (it was supposed to be "temporary" 25 years ago) and starting from scratch and this gave me the opportunity to do that. I also took the opportunity to move a wall so that the room is about 25% larger, which should mean that I can have 3 or 4 towns far enough apart that a 20 car train has left one town before it arrives at the next one :cool:
BTW, seeing that using an SK60 module would make quick work of the power supply project I decided that it was time to pursue something else I've wanted to for years so I ordered some Arduinos and related stuff but that is all on hold too.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,968
I got involved with Arduino a few years ago when I had a Bluetooth project. The project didn't go anywhere, but I still have the Arduino and the Bluetooth boards that plug into the Ardino board. I might revive that part of the project as part of a home automation project that takes advantage of a new Eero wireless router and a fiber-optic Internet service. But since acquiring the Arduino and Bluetooth boards I also got involved with Microchip PIC (Programmable Interface Controller) products. This company has been around for a long time, filling a niche market for "smart" main-frame computer peripheral controls. I never worked with main-frame computers, so I was not familiar with PICs until KrisBlueNZ (deceased) on ElectronicsPoint brought them to my attention. These devices remind me of my work with Intel 8080 and 8085 microprocessors in the 1970s.
Most of what I learned about PICs is probably obsolete now, but I like to work as close as possible to the actual hardware and "bang on the bits" with assembly coding instead of using an abstract high-level language such as C, C++, Python, BASIC, FORTRAN, etc. Of course abstraction is a powerful tool, but today it just seems to create bloatware. Faster tech just enables sloppy programming, but if machine-AI takes over the programming role that trend may reverse.
It looks like the lower forty-eight has survived another Canadian Clipper. It got really cold here in Florida: I woke up to 58F morning temperatures! That means a light jacket if I venture outside, but the Snow Birds are flocking around in shorts, T-shirts, and sandals (Crocs usually) like it's summer time! So, if that's your bag, hop onto one of your sidecar-equipped motorcycles and head South on I-75. Stop when you reach Tampa. We are all full up further south. <wink, wink>
Sidecar Bob
Dec 19, 2021
268
I'm mostly interested in Arduinos for their potential uses in model railroading. Digital Command Control (DCC) has been around long enough that I bought a used controller 3rd hand over 10 years ago. It controls decoder equipped locomotives well enough but there have been a lot of improvements since it was new. But sophisticated new systems cost a lot more than I'm willing to spend and there's a lot of information on the web about how to assemble a system with Arduinos &c for a lot less, including open source software and things like that.
