yummymetalman
- Dec 31, 2022
- 7
- Joined
- Dec 31, 2022
- Messages
- 7
Hi guys.. im oliver. Im just new and not knowledgeable enough in the behavior of the ir2110.. i have a problem in my circuit.. im trying to make a class d amp using the ir2110.. but im testing it for now in the ltspice with the use of pulse signals from two voltage sources. Each have a dead time(Lin, Hin).. it is working with the supply of 100 volts using irfb4227 mosfet.. i have an output of pulse signal which is ok..
But the thing is, how am i gonna make an output that starts from 0v, -100v to +100v or from 0v, +100v to -100v from my half bridge config mosfets? Or shall we say, how make it that has an alternating pulse output from both positive to negative supply voltage swings vise versa?
I have attached a files to make things clear.. i maybe incorrect in making the circuit that is why im refering to you guys!! Thank you so much for the help!
