Ommatoiulus
- May 17, 2023
- 4
- Joined
- May 17, 2023
- Messages
- 4
Hello people,
I picked up a small second-hand speaker with 'Aux' input a while ago to use in my car. I tested it today and it worked neatly both on batteries and with a power cable from USB to its 4.5V port.
Fatefully, I also had a cable going from a car 'cigarette lighter' plug to a connector that, with an adaptor bit, fit the 4.5V port. Stupidly overlooking that the car lighter socket would give 12V, I tried that cable. Result: a hissing/frying sound. Turned off the speaker but was left with a slightly smoking and smelling, and soundless, device.
I know very little about electronics but had a look inside. There is a metallic rectangular component (Integrated Circuit or something else?) which seems to have fried, judging by its smell:
The led is still shining when 'on' both from batteries and USB power, and a multimeter gives about 4.4V between various points, e.g. between the 'feet' of each black cylinder (capacitors??), and on the two speakers themselves (between the attachment points of the black and the white wire, and between those of the red and the yellow wire).
I'm guessing the thing might still be receiving power OK, but the fried larger metallic bit is involved in actually channeling the sound? Is that part possibly replaceable?
Or is it likely that other bits are also damaged and it's a total loss?
Pardon my clumsiness/ignorance, and thanks for any insights.
Here's the innards:
and the other side:
Here's the innards:
and the other side:
