Spectrum analyser Equalizer project how to go about it?
Maglatron
Jul 12, 2023
2,025
ok so I'm confused how do you map the frequencies to the columns and have the amplitude update every time the column moves to the next in line
I'm thinking of wiring up the leds in the configuration of ws2812b wiring diagram is it transposable to my led matrix
Maglatron
Jul 12, 2023
2,025
so say the cycling is 24 columns each for 25hz then 600 pulses each light will be on for 1/600 = 1.67milliseconds and I want to display the amplitude for this column each time the light is on gives me 1.67 second to process and display the leds which is pretty tight and the lights won't be on for long, I'm sure there is a more efficient way of doing this. help needed?
Maglatron
Jul 12, 2023
2,025
essentially I want this but I want 24 columns and 20 rows, but he didn't upload the code!!
Maglatron
Jul 12, 2023
2,025
I found the code it uses
WS2812 LED panel​
can it be adapted to work with my 24 column 20 row (where the anodes are connected down the columns and the cathodes across the rows) the frequency goes from 32hz to 16khz logarithmically going from 32, 37.72, 44.5, 52.49, 61.96, 73.15, 86.35, 101.92, 120.22, 141.65, 167.01, 197, 231.49, 271.48, 318.23, 373.12, 437.88 515.5, 609.39, 722.35, 857.56, 1015.84, 1199.54, 16000 in Hz
  • esp32_spectrum_analyzer_32x16.ino
bertus
3,837
Hello,
There must be a failure in your frequency list.
You jump from 1199 to 16000.
What happens to the frequencies in between?
Bertus
Maglatron
Jul 12, 2023
2,025
not sure il work it out again does anybody have a .zip file for the esp32 because my internet does not allow me to download and add
Maglatron
Jul 12, 2023
2,025
ok how would you split the columbs from 32 on the left an 16000 on the left evenly spaced in between
Maglatron
Jul 12, 2023
2,025
perhaps these numbers are better
  1. 41.5 Hz
  2. 53.8 Hz
  3. 69.8 Hz
  4. 90.5 Hz
  5. 117 Hz
  6. 151 Hz
  7. 196 Hz
  8. 253 Hz
  9. 328 Hz
  10. 424 Hz
  11. 549 Hz
  12. 710 Hz
  13. 917 Hz
  14. 1186 Hz
  15. 1532 Hz
  16. 1980 Hz
  17. 2559 Hz
  18. 3306 Hz
  19. 4265 Hz
  20. 5489 Hz
  21. 7050 Hz
  22. 9032 Hz
  23. 11631 Hz
  24. 14955 Hz
Maglatron
Jul 12, 2023
2,025
I run it and then it flashes up with a black cmd box momentarily
