VR + VL + VC = 0 V is o.k.
WIth the current direction as shown this directly translates to
[math] i \times R + L \times \frac{di}{dt} + \frac{q}{C} = 0 V[/math]I don't know why you use negative values in your equation, but this is a mere formal complaint as both your and my equation are equivalent since the result is 0 V and in your 4th line on the left you miraculously come tothe samea similar result, but why do you change the integral from [math]\int i dt[/math] to [math]\int v dt[/math]? This is wrong.
Coming to the right side: you make matters unnecessarily complicated by distinguishing IR, IL and IC. Since this circuit has only one loop, IR = IL = IC = I simplifies writing down the equations. You furthermore make it very difficult to follow your writeup when you e.g. [math]V = L \times \frac{di}{dt}[/math] without using the subscript "L" for VL.
Please correct your writeup so we can follow your reasoning without headaches.
By the way: It is imho good practice to keep the units into the calculations. This allows to check the result: If the units don't match there is definitely an error in the calculation.
but the question is "determine the characteristic equation for the voltage across the capacitor (iC), the voltage across the inductor (iL) and the voltage across the resistor (iR)." did I just solved the problem asked?Looks o.k up to this point:
The next 2 equations are imho not helpful.
The equation now has the form x''+ax'+bx = 0 with a = R/L and b = 1/(LC). This second order differential equation can now be solved using with some help from the internet, see e.g. this page. Once you have the solution, you can re-substitute a and b by the respective expressions.
Btw: Your thread headers are not very informative. Instead of "help meeee I have my answer but I'm not sure" something like "help me solve an LR-circuit" immediately gives our members a hint what your question is about.
Using Laplace transforms, we can write the equation as Is1 (R1 + L1 s + 1/(C1 s)) - L1 Io + Vo/s == 0. Solving for Is1 we get Is1=(C1 (Io L1 s - Vo))/(1 + C1 R1 s + C1 L1 s^2), Usng the many computer programs we can find the inverse Laplace transform asView attachment 61341
AI says the equation looks like this when written as a formula:
[math]i = \frac{ e^{-\frac{\left(R_1 + \frac{\sqrt{-4 L_1 + C_1 R_1^2}}{\sqrt{C_1}}\right)t}{2 L_1}} \Bigg[ \left(1 + e^{\frac{\sqrt{-4 L_1 + C_1 R_1^2} \, t}{\sqrt{C_1} L_1}}\right) I_0 \sqrt{-4 L_1 + C_1 R_1^2} - \sqrt{C_1} \left(-1 + e^{\frac{\sqrt{-4 L_1 + C_1 R_1^2} \, t}{\sqrt{C_1} L_1}}\right)(I_0 R_1 + 2 V_0) \Bigg] }{ 2 \sqrt{-4 L_1 + C_1 R_1^2} }[/math]To be honest, I haven't checked the result thoroughly.
@Ratch : in case you haven't noticed: this thread is from 2023 with no further reply from the op. In fact the op has been seen here the last time on November 3, 2023.
You do not solve anything you just regurgitated a textbook or AI did good for you.I solved this problem to show others how much easier
Yes, I know the post is two years old and the OP has probably died by now. I solved this problem to show others how much easier Laplace Transforms make the the problem. That is because the initial conditions are carried along with the solution process and no back substitution algebra is necessary. That saves a lot of work. Who would think that two simple initial conditions would result is such a complicated current equation. I chose the values of L1 and C1 to resonate at 1 kHz. If we set R1 to zero, notice how the oscillations go on forever.
Lock her up!
You’ll need to specify the circuit (series or parallel RLC) and what variables are defined, otherwise it’s not fully solvable.View attachment 61341
