I Agree and I deleted that post.you make no sense
Passband, aas the name says it the range of frequencies that pass the filter.still not sure about stop band or what it does.
Better use the TL074H (comparison).can use one of the built in op-amps of the TL074
I have TL074CN type, will these sufficePassband, aas the name says it the range of frequencies that pass the filter.
Stopband,, as the name says, is the range of frequencies that do not pass the filters, that are stopped.
After the filter you will have an AC signal containing the frequency componnets of (mainly) the passband. You will need to rectify and filter this AC signal to get the envelope which is what you'll want to display by the LEDs.
ok so this is to make DC for the LM3914 to read, I need a little more information on how to do this but it does make senseAfter the filter you will have an AC signal containing the frequency componnets of (mainly) the passband. You will need to rectify and filter this AC signal to get the envelope which is what you'll want to display by the LEDs.
like filterwizardgetting the envelope which is what you'll want to display by the LEDs.
When I search for "envelope detector" I get lots of results from the internet. Don't let us do your job. You know how to use a search engin, puit that knowledge to the test.help please
