Sallen Key Low Pass Filter, bandpass filter
Maglatron
Jul 12, 2023
2,025
Hello,
You can set the sensitivity of the LM3914 or LM3915 by changing the Rlo (pin 4) and Rhi (pin 6) voltages.
The Rlo will set the lowest led and Rhi will set the highest led.
Bertus
how to set Rhi.jpghow do I set Rhi please?
Maglatron
Jul 12, 2023
2,025
Hello,
No, The V- should go to the - of the 12 Volts.
The Rhi could be a value between Ref and +12 Volts.
Bertus
I'm just going to leave it at 12v or put a variable resistor 10k
Maglatron
Jul 12, 2023
2,025
I think this
Maglatron
Jul 12, 2023
2,025
Is it correct?? I think it looks good to go! if not can you modify the diagram to express how it should look please?
Maglatron
Jul 12, 2023
2,025
I've got the part in green but have to get it connected to the LM3914! (green part)diagram.png
Maglatron
Jul 12, 2023
2,025
I get why the REF virtual ground is put to the Rlo, it's because 6v is the lowest instead of 0v and the upper limit is between 6v and 12v I just don't know how to set it up
bertus
3,849
Hello,
The Rhi is dependend on the signal you get out of the detector.
Set Rhi in such a way that the maximum of the detector shows all leds.
Bertus
Maglatron
Jul 12, 2023
2,025
please can you draw the schematic so I can work it out looking at the correct configuration because I don't understand, I'm lost, I need an image of the circuit running off a 12v source please please please can you do a design of the cascaded bar type LM3914 with the REF virtual ground from the buffer circuit, and the actual ground and resistors, I would be so extremely thankful and will appreciate it I'm just trying to picture it and follow the directions I have read in the documents, but to be honest dont really understand them fully and I think that if I can see how it's done and read back over it, then I will understand
Maglatron
Jul 12, 2023
2,025
It's like if I know how it's supposed to look and know why it works that way, then I can understand it, but trying to figure it out on my own is like putting together a puzzle without a picture on it! so please provide me with the images I need, cheers
Maglatron
Jul 12, 2023
2,025
I got this far in the chain just need little nudge in the right direction
Maglatron
Jul 12, 2023
2,025
for the 9 volt at the beggining I will use a voltage divider Vout = Vin x (R2/R1+R2)
pick R1 to be 10k
9V = 12V x (R2/10k+R2)
solve for R2 = (9V x 10k/12V-9V)
R2 = 90k/3V
R2 approximatly 30k!
Maglatron
Jul 12, 2023
2,025
do I just put the REF vitual ground to the Rlo in this video and +V to 12v and ground from the 12V supplt to ground of the chip? cheers I think thats correct but I still don't understand how to set Rhi. So I think you disconnect Rhi from REFout and put a desired voltage, correct?
Maglatron
Jul 12, 2023
2,025
So I have read and re-read the datasheet and I'm still confused, I can see that VRlo needs to be greater than zero and VRhi needs to be less than 12V so I know how to set the Rlo that bits easy, just put the REF virtual ground. But how do you set the Rhi to 12v because Rhi and refout are connected ? cheers
Maglatron
Jul 12, 2023
2,025
I recon I'm overthinking it can you screen shot and red box the part that tells me where and how to set Rhi to 10Volt please?
Maglatron
Jul 12, 2023
2,025
Vout_ref = 1.25×(1+R1/R2)
10V = 1.25×(1+R1/R2)
solving for R1/R2
R1/R2 = (10V/1.25)−1
R1/R2 = 8−1
R1/R2=7
choose specific resistor values that satisfy this ratio
R1=1kΩ and R2=7kΩ
Does this look right?
I think this maybe right!!
Maglatron
Jul 12, 2023
2,025
It was right infront of me the whole time, sorry for that guys, it's just clicked!
Maglatron
Jul 12, 2023
2,025
Have I overlooked anything other than that which I did? cheers
