My goal is to mount an alternator to the lawn tractor's PTO shaft. The reason is to increase the amount of available power to operate 12v accessories, like winches, raising/lower a dump bed, or running an inverter for 110v. The battery I have is a small lawn tractor battery and it doesn't have the capacity for it. It will run down and its life will be significantly shortened. Additionally, the onboard charging system is not powerful enough to handle the job of recharging this battery in a timely manner, nor was it made to handle the kind of demand that I need. I have a used spare alternator I thought would do the job.
I may replace the current battery with a deep cycle one, but I don't want to spend the money at the moment, and without an adequate charging system it would be pointless anyway.
So far, I've successfully mounted and mechanically connected the alternator to the PTO output shaft via a v-belt. The alternator belt spindle has been replaced with a v-belt type. The alternator can be spun separately via the tractor's PTO switch.
My issues are with the electrical connections. My electronics knowledge is limited at best. I know the difference between volts and amps, what basic electronics components do, and I can do electrical connections. But designing an electrical system is out of my league. My day job is a software engineer, if that matters.
This is the alternator that I have:
Note that my alternator is a Motorcraft brand, but this is a direct replacement, so the interface should be the same.
The wiring diagram for this alternator is here: https://www.f150forum.com/attachmen...-wires-out-charging-system-wiring-diagram.pdf
Apparently this alternator takes in a PWM signal through wire 2 (GENCOM).
I don't have the ability to generate that in a purely analog system of a lawn tractor and I need the simplest way to make this alternator output 13-14v to keep the battery charged and feed any additional load that I may need. I am prepared to modify it if necessary. Using a different alternator would mean I would have to rebuild the mounting system which I don't really want to do, unless I have no choice.
What I have connected so far: The big red wire is connected to the battery positive. The alternator is grounded to the tractor chassis which is connected to the battery negative. I connected wire 1 to positive battery. I once connected wire 2 to negative (unintentionally, without spinning it, wire 1 was loose at that time) and then to positive (intentionally, with the engine on). At this point I am not sure if I damaged the alternator doing this. Then I read somewhere to connect wire 2 to wire 3. I thought that the GENMON signal sent might be similar enough to some acceptable form of a GENCOM signal to trick this thing into producing electricity. It wasn't or it's broken already. I don't know how to test this alternator. I don't even know if it was good to begin with as it was pulled from a junk truck. But let's assume it is, for the sake of progressing.
None of those combinations produced any voltage above 12.5v that I was reading at the battery terminals. I disconnected the tractor's charging system while I did this, to prevent interference. I don't know if I can run them safely at the same time, but would like to, because this alternator won't be activated at all times, only when I need a lot of power, and I don't want the battery to run down from normal use.
