roughshawd
- Jul 13, 2020
- 616
- Joined
- Jul 13, 2020
- Messages
- 616
Why? Unless you know what they are for or what they do then LEAVE THEM ALONE. Just 'doing things' isn't going to get this fixed. It will make matters WORSE.Should I remove them?
Please answer my questions FULLY - unless you don't want this fixed???When the power is off yeah...
No.Is this supposed to be a fuse location?
Please answer ALL the questions......4. If it drops to ~3.5V when you connect it (VHF switched off) has your PSU gone into current overload protection?
Well, that's me 'out of here' then.Pulled the green wire jumpers, and installed JST breakout between broken black lead points... Has 55.7k ohms on breakout.
As this post should be!Still 3+ volts at the board.
Still dead as a door nail.....
What does that mean?.and most of the resistance.
My Astron 12 A delivers 12v. Tested good.What does that mean?.
Stop smoking the funny stuff!.
If it’s supposed to have 12V and you don’t have that, then first check the input signals to and from the source.
