Horizon radio reset for power failure....
Status
Not open for further replies.
roughshawd
Jul 13, 2020
618
This is where the cut wire is located on the case shell... Looks like it may have gotten cut or smashed when the case was puton.
kellys_eye
Jun 25, 2010
6,512
Should I remove them?
Why? Unless you know what they are for or what they do then LEAVE THEM ALONE. Just 'doing things' isn't going to get this fixed. It will make matters WORSE.
When the power is off yeah...
Please answer my questions FULLY - unless you don't want this fixed???
1. What power supply are you using?
2. Can it deliver 13.8V at 2A MINIMUM?
3. Does the applied voltage (13.8V) remain at 13.8V when you connect it to the VHF?
4. If it drops to ~3.5V when you connect it (VHF switched off) has your PSU gone into current overload protection?
roughshawd
Jul 13, 2020
618
I have an astron 12 v 12a power supply
It return 12.12v according to my multi meter
roughshawd
Jul 13, 2020
618
Is this supposed to be a fuse location?
If so, what size do I order?
roughshawd
Jul 13, 2020
618
Also, thoc image shows the broken black jumper lead , and a metal clip that holds the microphone into the socket. These are right where the case closes watertight. The residue of the black jumper says it maybe arced across this. I don't know if there was a component on the black jumper or not. If someone can help me there I would be very happy! If a component was crushed there, when the radio was assembled that could cause the fuse failure.
roughshawd
Jul 13, 2020
618
In the shop with better natural lighting...
Your cheesecake picture of the power section.
.(frankly, I have told some others this....old Radios are generally powered with external PSU because of noise, but the modern ones don't use external PSU, they are powered by a common power, and as a rule of thumb, they usually don't have a special "power section". Just extra fuses).
The power section photo is yours to keep...!!!
kellys_eye
Jun 25, 2010
6,512
If you PSU is truely 20A capable and the voltage drops to 3.5V (no current limiting) then there should be smoke coming from something.
Connect the 12V supply to the VHF via a fuse (rated at 5A).
You may have to remove the whole PCB and show the rear of it in clear pics too.
kellys_eye
Jun 25, 2010
6,512
In the close up pic of the wires going onto the man board (the pic with the yellow and black wire at the top), there is a small 'square' located in between the positive and negative tracks - showing as four solder blobs. This MAY be a protection diode but mounted on the other side of the board hence my request above for a pic of the rear of the circuit board.
roughshawd
Jul 13, 2020
618
Pulled the green wire jumpers, and installed JST breakout between broken black lead points... Has 55.7k ohms on breakout.
Good signal series vertical on the test of those....
roughshawd
Jul 13, 2020
618
My jumper breakout....
kellys_eye
Jun 25, 2010
6,512
Well, that's me 'out of here' then.
You clearly have no clue what you're doing or even why. I'm sorry to suggest that anything I might say or offer as advice will be totally ignored or over ridden by your clueless and irresponsible actions.
Suggest you pack that VHF in a box and use it as a paperweight.
I'll have no more to do with this thread.
roughshawd
Jul 13, 2020
618
Thanks... You needed that....!!
To take a brick and throw it through a windows, is destruction, But to use that same brick to build a new home is progress. That is assuming you are mason, or as the case may be .. terrorist.
Does not look like a brick too me...
roughshawd
Jul 13, 2020
618
If a device just won't turn on, what is usually the cause??? Cause I checked the fuse, the line, the regulator, the caps, the connections, the accessories, the main amp, and most of the resistance....
There is a constant 3v running where there should be 12v.
roughshawd
Jul 13, 2020
618
What does that mean?.
Stop smoking the funny stuff!.
If it’s supposed to have 12V and you don’t have that, then first check the input signals to and from the source.
My Astron 12 A delivers 12v. Tested good.
My radio is sucking up about 8 or 9v when it is connected.
At the board on the wire harness where the fuse and ground lines connect.... The meter reads >3v.
The radio will not turn on.
ivak245
Jun 11, 2021
144
Buy a new radio. A radio should not be sucking up any voltage. If it does that, you may actually have a vacuum cleaner. Mine sucks up everything-voltage, current, induction, and on a good day, impedance.
Status
