Horizon radio reset for power failure....
Status
Not open for further replies.
roughshawd
Jul 13, 2020
618
LOOK WHAT I FOUND!!!
roughshawd
Jul 13, 2020
618
There are 2 black wires... They are both disconnected!!! I don't see where they connect
kellys_eye
Jun 25, 2010
6,512
The ribbons look to me to have a release clamp on the connectors.
That 'black' thing is possibly a 'filler' cord they use in multi-core cable. If it doesn't have a wire core then that's precisely what it is.
roughshawd
Jul 13, 2020
618
The ends look burned off. They connect to the board under the red tape...
roughshawd
Jul 13, 2020
618
I need a schematic for the WG444X201-2
What about the opens in the black wires?
roughshawd
Jul 13, 2020
618
Remove red tape, discover connection.
roughshawd
Jul 13, 2020
618
What should I do now?????
What if I connect my multimeter to the wires to check for voltage? ?? Hehheh such small wires!!! I will need to be miniaturized with a very sharp an proper sized wire stripper.
kellys_eye
Jun 25, 2010
6,512
Don't mess with them (yet).
With the set the right way up, put the black shorting link (behind the rubber plug you mentioned at the start of the thread) on the BOTTOM two pins.
PRESS and HOLD the CALL/SET button on the front panel whilst powering the set up. What happens?
roughshawd
Jul 13, 2020
618
12.22v
roughshawd
Jul 13, 2020
618
This would allow me to attach any thing I want there...
kellys_eye
Jun 25, 2010
6,512
So your power supply drops from 12V to 3.5V when it's connected to the VHF (and the VHF is OFF)?
What are you using for a power supply?
kellys_eye
Jun 25, 2010
6,512
What if I put this little jst connector where the black stubs are?
Feel free. It's your set. Who knows? It might work. It might also cause even more damage. Thing is, if you don't know what it will do then DON'T DO IT.
kellys_eye
Jun 25, 2010
6,512
Show a close up pic of this area of the circuit board - try to get it clear (not over-exposed).
roughshawd
Jul 13, 2020
618
Twisted spaghetti..mmmmm!
Ok the final dilemma of his fix....
There are a couple capacitors on the shield which look like aftermarket work, so maybe somebody tried to fix it before me and added these? There are also these two green jumpers.... Should I remove them?
Status
