Sallen Key Low Pass Filter, bandpass filter
bertus
3,868
hello,
what is the voltage in the middle of the two resistors?
bertus
bertus
3,868
hello,
the voltage should be on the + input of the opamp:
bertus
danadak
Feb 19, 2021
1,100
I have not read this entire thread but hanging 10 uF and 100 uF on
the output to ground I would think ill advised due to stability issues.....
Regards, Dana.
Maglatron
Jul 12, 2023
2,025
got new proto board going to make a start on the circuit from the beggining with colour coded wires and thats the (mic to pre-amp, amp, and REF GND circuit and then the filters and buffer) hopefully get the right results this time
Maglatron
Jul 12, 2023
2,025
is this be right? included original so that you can edit if wrong!
Maglatron
Jul 12, 2023
2,025
bertus
3,868
Hello,
Yes, if you follow those colors, you will have more overview over the signals.
Bertus
Maglatron
Jul 12, 2023
2,025
got a box pack of caps, can I use the electrolytic 100nF instead of the film ones?
bertus
3,868
Hello,
Are you sure that the 100 nF capacitors are electrolytic?
If they are electolytic, I would not use them in the filters, but only for decoupling the power supplies.
Bertus
Maglatron
Jul 12, 2023
2,025
no the the 100nf caps I'm using are film type but I was just saying that I have electrolytic ones in the box I bought I do remember you saying that the 10uF ones on the REF GND circuit would be fine though!
