Do I need a constant current or voltage power supply to drive 12V Halogen lights?
Bluejets
Oct 5, 2014
7,374
My apologies for this basic question. I need to replace a 12V power supply to drive 2x 20W halogen lights.
Led driver not made for Halogen lights which do not require either constant voltage or constant current.
Halogen lights are a thing of the past, wayyyyy too much heat dissipation.
It might work though, as they say , suck it and see.
Can only cook itself.
I'd be buying a couple of LED lights which, complete, and plug straight into mains supply, would be less than what you intend to pay for the LED driver.
dave9
Mar 5, 2017
1,191
Yes that should work, but ideally for long life, I would want something rated for more than 5A, to power a ~3.3A load. Opinions may differ but when choosing a generic chinese PSU, I want more current margin than that, as some aren't even accurately rated in the first place.
You could use something constant current rated instead, but I would want to measure the actual current consumption of these bulbs in parallel at a constant 12V in order to know what that constant current is, so far easier to just get a traditional 12V voltage regulated PSU.
I agree about considering use of LED bulb instead of incandescent, unless this is a unique situation like landscaping lights, where in winter, you want the extra heat to melt off snow and ice. I mean that even if this is an existing lighting product like under-cabinet lighting, you could replace the 2 x 20W incan bulbs with LED bulbs and then not even need as much as a 1 amp PSU to provide as much LED light, but would still want a 12V, voltage regulated PSU for a bulb rated for 12V.
