corporal_Canada
- May 8, 2024
- 28
- Joined
- May 8, 2024
- Messages
- 28
hello, i am a french Canadian residing in the beautiful Philippines, please forgive me if my English isnt UK perfect but here goes...
Okay I have this... Inside is a 12v 7ah ups battery sealed.... But I want to replace it with 2x 12v 50ah solar bank SLA battery, feel free to say if I'm croaching on Oppenheimer territory or I'm onto something genius.... I'm worried that I might burn the charging part of the ups.. but if my french dumba$$ is correct. Having 600 wh or 1200wh will allow my PC and monitor to run for 4 hours instead of 4 seconds in case of a power outage......
my pc tower only pulls 100-130 watts monitor pulls 25-27 watts.. fiber optics wifi modem pulls i dunno 5 watts ??
totalling.. maybe 200 watts
here is where it gets interesting... im currently using these 2x 12v 50ah batteries in my solar system setup... connected to them is a mppt (glorified solar charge controller) into THAT is 3 solar panels that all claim to be 300 watts plus... but.. ive been here long enough not to believe everything China claims...so lets just ASSUME i get a minimum of 150 watts or around that figure.. i TRIED plugging in 3 items into it.. pc tower, monitor.. and fiber optics modem.. assuming the wattometer that i tested with wasnt on its period.. all 3 items pull 150-200 watts... means im pulling more than the panels are providing.. so here is my alcohol induced thinking.. what if i keep the 2 batteries as is and connected the ups insides onto the 2 batteries... and the mppt gives the batteries its tiny 150 or 200 watts and the ups still being duct taped to the wall outlet or grid and yes im kidding about duct tape... gives whats left... this would be handy at especially at night...
yes im aware that the charging circuit will overheat.. i ordered a dc powered fan with pos and neg clamps to negate the heat...
no, i am not half Canadian billionaire genius Elon Musk so i dont know how to test the circuitry of the ups.. i only took dc basics in high school...
more info on the batteries.. both CLAIM to be made in germany.. company called DCpolarity... solar bank.. so... AGM right ?... however there are refilling slots on top so.. im doubtful a bit....
both batteries are linked in PARALLEL using a 6 gauge wire (parallel keeps everything at 12volts in case you forgot)
im aware that 6 gauge isnt sufficient but the batteries and cables are at arms length so i consistently feel for temperature change....there is also a 80 amp fuse from mppt to pos of 1 battery...
what im trying to ask is.. can i keep my solar system as is and use the UPS to refill the 2 batteries without creating a wormhole to Narnia ??
