Hi everyone,
I’m working on a project involving the Bluetooth audio module powered by a 3.7V 3200mAh Li-ion battery. While the module technically supports a voltage range of 3.7V to 5V, I’ve encountered a significant issue when the battery voltage drops below 4V. As the voltage decreases, the audio quality from the BT module deteriorates dramatically, resulting in noticeable distortion and hissing sounds.
Here’s what I’ve tried so far:
Direct 5V Power Supply: When I directly power the BT with a stable 5V source, the audio quality is excellent. This leads me to believe that the issue is indeed related to the lower voltage from the battery as it discharges.
Ordered XL6009 for increase the voltage but it is not worked as we want.
First i wired it direct and there is too much noise in sound , then added a capacitor (25v 2200uF) less noise but still there.
I need a reliable solution to ensure a constant 5V output from my 3.7V Li-ion battery to maintain good audio quality.
Any advice or recommendations for a more effective power management solution would be greatly appreciated. Thanks in advance!
