roughshawd
- Jul 13, 2020
- 616
- Joined
- Jul 13, 2020
- Messages
- 616
These are the diodes I am using. https://www.alldatasheet.com/html-pdf/61332/FUJI/D83-004/81/1/D83-004.html
when a signal crosses a component, the polarity changes
Positive ---component--- Negative
Electricity always travels one way until it hits terminating resistance.
Then it swaps direction.
when the component is installed in series, it is generally accepted that one terminal is positive, and the other is negative.
See the light reflection on the top of the caps? The right has a light running across the top and the other is diffused? The right cap has a bulged top.
I can agree with this observation.The right has a light running across the top and the other is diffused? The right cap has a bulged top.
The bulging capacitor in the image is 5uf lower than the one on the right, and will trigger sooner than the one on the left.I can agree with this observation.
Light coming from the left is reflected on the right side of the left capacitor, indicating an indentation.
The same light is reflected in he left side of the right capacitor, indicating a bulge.
Just to clarify.... Schematic diagrams are based on ideal circuits...
Where the diagrams is more of a guide than it is the actual circuit, as this will vary a bit based on the type of circuit and it's use....
What do you mean? Trigger what? The bulging cap is defective and should be replaced.and will trigger sooner than the one on the left.
Compared to which nominal value? As these seem to be rather big capacitors, a difference of 5 µF is most likely well within the specified tolerance of the capacitors.The bulging capacitor in the image is 5uf lower than the one on the right,
+1 for this question.What do you mean? Trigger what?
