Need help in reverse engineering this power failure alarm circuit
divyanshl
Mar 15, 2026
4
Namaste,
I need help to reverse engineer and get the schematic diagram and the BOM of a power failure alarm which has the attached circuit board. It runs on a 9V battery during power failure, and provides a 120db alarm aound output. Can anyone please provide any help.
Martaine2005
May 12, 2015
5,314
I think you’ll be alone with this request.
Surely you can make a BOM yourself as it’s all in front of you!.
Apart from a few resistors, we can’t even see the markings of the ICs. Q1 and U4 especially.
What’s the need for reverse engineering this apparently simple circuit?.
Use a torch to shine on the back of the PCB and you’ll see what’s connected to what.
divyanshl
Mar 15, 2026
4
Thanks for your response Martaine. The markings at Q1 and U4 have been etched out as is typical in chinese manufactured circuits. This is why I needed the help primarily. I'm struggling here to figure out this circuit because of that reason. I've used AI to figure out what Q1 and U4 are, but whatever it suggested(LM555, LM393, NE555, LM2903, MC34063) do not work in U4.
I must admit that I am no expert at this.
Delta Prime
Jul 29, 2020
2,993
Could you take another photo at a different angle of Q1 & U4 I do see some markings on it.
also, can you determine the working DC voltage of the blue electrolytic capacitor? if you look on the side of that component, you’ll see marks on it please write that down. Thank you…
The battery connection below circled in yellow is not indicative of a 9 V battery but I have to take your word for it. :)
Your surface mount PC 817 the four pin Opto coupler runs on 5 V and will turn on the alarm in the event of a power failure.
The reference designator on the PCB, ZD1 your zener diode connects directly to the six pin surfacemount, IC. I believe it’s just a switch,see photo below; to turn on your 120 dB
piezoelectric buzzer.
  • PC817X.PDF
divyanshl
Mar 15, 2026
4
Thanks Delta Prime for your response. Sorry for the late reply.
Yes, you were right that the working voltage indeed is 5V. However, I can confirm that there are no markings on the electrolytic capacitor, either because it was etched out, or wasn't present in the first place. But the fact that a 9V battery is used during power failure is undisputable as this is what is provided by the alarm sellers and it's what works with it too.
The Q1 marking seems to have J3Y on it, but I have yet to try the MOSFET IC and once I do, I will get back to you about that.
Samuel616
Sep 22, 2026
6
Namaste,
Hi, I'm interested in this work. Did you get a BOM and design file from reverse engineering?
I have experience in PCB reverse engineering work, so I can help you.
Sam
divyanshl
Mar 15, 2026
4
Sam
Hey Sam,
Thanks for your response. I tried with two guys but they weren't able to reverse engineer it so I just gave up on it. If you are able to reverse engineer it and provide me the BOM and design files that would be great but I'm guessing you need the device physically present with you to do the same, how to do you propose to get that, I can order it for you and get it shipped to your address perhaps. Also, if you can specify your asking fees for the this work, or we can contact with each other to discuss further.
Samuel616
Sep 22, 2026
6
Okay, I can order the device myself, or you can have it shipped directly to my address. I’d also like to discuss the project details with you so we can go over the requirements and next steps.
Samuel616
Sep 22, 2026
6
Hi, please feel free to connect me any time. samuelwieser030 at gmail dot com
