0-30 Vdc Stabilized Power Supply
audioguru2
Apr 6, 2004
12,022
FireFly,
Yes, the 44V rated TLE2141CP is a good substitute for the TL081 in this project.
Xenobius1
May 28, 2004
103
Ok People I fixed it :D
So take this as a tip:
IF IT varies the voltage from 23v to 35v ONLY, you got the Emitter and Collector of the 2N3055 Mixed UP lol..
Cheers!! when I arrive home I will post some pictures if the administrator lets me (until I arrive home I hope the administrator will already have posted if I can post pics or not)
10x
audioguru2
Apr 6, 2004
12,022
Xenobius,
Good. I'm glad that you spotted and fixed your problem.
So the 2N3055's emitter-base junction was avalanching like a zener diode, in series with the base-collector junction. No matter what voltage the output of U2 was providing, the output could not follow it down.
Now you can remove those fuses which reduce the supply's performance:
1) Remove the fuse at the transformer's secondary, since its resistance limits the huge momentary current through the rectifiers when they charge C1, when the supply is loaded.
2) Remove the output fuse, since its resistance spoils the supply's regulation, when the supply is loaded. This supply has an adjustable current-limit so the fuse is not necessary.
Xenobius, could you please measure the voltage across R1/C1 without any load, and again set to 30V with a 3A load?
FireFly3
Dec 7, 2003
35
And one more substitution please: 2N2219
I can't seem to locate these in a form easily attachable to a heat sink. Can someone suggest another model(s) suitable for this circuit that would be easier to find in a "heat sink form" such as TO-220?
Thanks again (for the umteenth time!)
ante1
Jan 24, 2004
4,136
Xenbius,
Congratulations, Now everything is perfect. Can I ask you how the PSU performs, what is the maximum current @ 30Volts without voltagedrop?
Ante ::)
audioguru2
Apr 6, 2004
12,022
Firefly,
Use a TIP29 or TIP31 to replace the 2N2219. Their TO220 case can be bolted to a good heatsink.
Since their current gain is less, change R15 to 100 ohms.
ante1
Jan 24, 2004
4,136
Xenobius,
First I have to say; It look very nice and tidy built, good job!
You can
Xenobius1
May 28, 2004
103
Hehe thanks buddy for the compliments :D and sorry for the 50w resistor :p because I don't have one.
Here is another picture of it so even the people who are going to build it will have an idea of the layout :) (sorry for the dirt on the table but I was just drilling a PCB lol)
ante1
Jan 24, 2004
4,136
Xenobius,
Exterior as well as interior it is a very nicely put together project. What about my suggestion for your next project?
Ante ::)
Xenobius1
May 28, 2004
103
Right now I have 2 projects in mind the modification of that PSU to make it for 5Amps 30Volts and the Dummy Load.
Could you help me with both mate?
thanks
Xenobius1
May 28, 2004
103
ok thanks for the dummy load .. I will work on it as soon as I start/finish the 5Amp PSU mate :D
thanks for now
FireFly3
Dec 7, 2003
35
I'm aware that the filter cap is recommended to be much larger uF wise but I'm wondering about the voltage rating. The original part list called for a 50V cap. I may have found some large-enough, 250V caps. Would using caps with much higher voltage ratings do anything good or bad to this power supply? Should they perform as well as the same size cap rated at 50V? There must be some kind of trade off. Perhaps physical size or cost?
FireFly3
Dec 7, 2003
35
Sorry. My last post should have said 450v caps rather than 250V caps.
FireFly3
Dec 7, 2003
35
Sorry about my 2 previous posts. Please ignore my stupidity. I'm going back to bed now!
audioguru2
Apr 6, 2004
12,022
To All,
See the other post about fixing this project before simply modifying it for 5A output.
MonSSter
Jun 6, 2004
18
Hi! ... i'm new on this forum so i have some maybe allreday answered questions... sorry ;)
i'm wondering if someone has made a 5Amp modification and use the LM338 insted of LM317? is there a new PCB for that or something? Tell me what u changed...
I'm also thinking to do a dual power supply. that's two adjustable power sources. Can I build two PCB's and then use transformer whit "double secondary connectors".. i hope u know what I mean... and use it like that whit no further modification...
Thank you!
